What belongs here?
Any help on what belongs here please??
Also does anyone know why there is a "hook" in the middle of the parcel shelf (underneath)
VW Polo 9n3 1.9tdi 130pd if it helps
  • Replies 8
  • Views 1.2k
Mine had a box with warning triangle fluorescent coat etc in. Imagine either that or fire extinguisher, first aid kit etc
Edit: could be to hold a jack kit aswell
Edited by matt01
Jack goes in the spare wheel.
Personally I put a can of tyre 'weld' type stuff and a tow rope.
I think the little hook on the underside of the shelf is to hold up the boot carpet when accessing the spare wheel? Thats what i find it handy for anyway lol
it would have held the first aid kit (AFAIK)
the hook under the parcel shelf is to keep the boot carpet raised while you're fitting a spare, so you've got 2 free hands to lift the spare out, pretty clever IMO
The first aid kit goes on the otherside iirc, this would have been for a warning triangle (although that may have gone under the boot catch) or as previously said, a fire extinguisher as in a lot of European countries it's mandatory to carry one, so the dealer won't give it to us without charging extra (bastards) if there was one fitted then there would be a lot less car fires...simples. In the hand book it should say what it's for, I can't find mine but I guess it can be used for many things?
Also with the little hook that is for the boot carpet to catch on as above. Also on the topic of the parcel shelf I remember reading that when you have a tall item in the boot you can remove the shelf and turn it around and it will hang with the top of the held facing the back of the seats. I thought this was really cleaver because I'd you had rear passengers there would be nowhere to put the shelf.
HTH
thanks for the replies will check out the spare tyre and see if anything else is hidden under there also. Will look at buying a Fire extingusher/ warning triangle box.
Beers. Stops them getting shaken up.
True story.
