Water in the drivers footwell!
Hi all, just wondering if any of you with mk2 bready experiance know where this rain waters getting in from? I checked the battery tray. Its like a swimming pool in there. How is it suppose to be?
  • Replies 11
  • Views 1.4k
Should be a drain hole going through to the inner wing.
One side has a drain hole the battery side has not! So i guess its been welded! So litrally the same place as the other wing?
get an ozonemaster to remove the damp smell after
www.ozonemaster.co.uk
I brought a car that had a horrible stench, nothing got rid but ozone...
I have managed to secure a discount only for CP members using code--- MAN1210
10% DISCOUNT
My 1985 bready has developed the same problem, any joy with resolving this 1984Breadvan?
Spearmint
Had the same problem, turned out to be a hole under the battery at the back of the battery tray, just wacked some chemical metal on it, lick of paint and a battery mat! sorted! could do with a full length scuttle tbh
3mm drill bit straight through the carpet, no more puddles.
Pikilosophy ftw
no, but your carpet is still getting wet as is the floor, from above and below, through an untreated hole... so it may not puddle, but your floor will rot like mad.
I think he was joking to be fair
there as a rubber pipe near the water pipes behind the engine which is a drainage pipe pull it off and see if its blocked mine was when my feet were getting wet
I had a hole in the floor on my breadvan and it was running from the back of the car down the ridges and soaking the carpet, the hole was tiny, maybe the size of a pinhead.
any chance of you grabbing a pic of this?
