Sound proofing/deadening
Hi guys, looking to sound proof the boot of the 6n2 soon and wondered if anyone could recommend a product? Not really looking to spend Dynamat money :|
Been looking at a few on eBay but I really don't have a clue what to go for, are the self adhesive ones much of a muchness and what sort of specs should I be looking for (thickness etc?)?
  • Replies 16
  • Views 3.4k
Personally, I have used household grade flash board tape. I get mine from builders depot which is a wholesaler. It is effectively the same thing (aluminium backed tar like stuff) which may need heating to bend to shape and stick better.
I did both doors, rear quarters, bot lid and boot for for less then £50 (5 rolls) so in this sense it is much cheaper then the alternatives and to my ears it is as good as others I have heard with dynamiat etc fitted. But it does take a little more effort to fit, which depending pnyour skills and time may not be worth it.
You can also use just the black "tar like stuff" which is already partially covering the boot floor, this comes in flat square sections and again once heated can be manipulated into most shapes. I get this from auto paint suppliers, I haven't covered the whole car in this, I only used it to replace the stuff I removed from my classic beetle, so this may not do the job as well as others.
HTH
Ahh okay thanks for that! I'll keep my eye out for the household stuff :)
dynamat ,
best stuff ,
I did both doors, rear quarters, bot lid and boot for for less then £50 (5 rolls) so in this sense it is much cheaper then the alternatives and to my ears it is as good as others I have heard with dynamat etc fitted. But it does take a little more effort to fit, which depending your skills and time may not be worth it.
HTH
I have used Dyna Matt Rockford Fosgate Deadskin and the flashing and I would never fork out for Dyna mat again the Deadskin was good and cheaper than DM but the benefits of the premium stuff is not worth the extra wedge......
EVO STIK FLASHBAND TAPE
its the same stuff sheet tar?bitchmin one side foil the other
a lot cheeper than dynamat does the same job
get down to your builders merchant
but then why would professional audio fitters tend to use products such as dynamat ? if they could use something so much cheaper ? personally you get what you pay for , show me evidence that things like this are better than the likes of dynamat and i will agree ,
Its not that flashing is better its just more cost effective and the installers use DM etc because they can they ain't paying for it.
By all means if you can afford to use DynaMat go ahead but I very much doubt you will notice the deference... :smoke::thumbsup:
Edited by Mk2 olop
They use it because it work , sound deadening is more than just stopping the panels vibrating, keeping the sound inside , it enhances the quality of sound too, no one can you say it does the same thing , if I was doing a job I would want to do the best job possible so would use the best materials, could easily use cheap crap and just rip them off , I think telling some one to use flashing is crazy too
Nobody said it does the same thing its just more cost effective.
If you have the money to waste on DM then crack on. :-)
My car is dynamatted so I don't need to do it but I think it's not great people giving out crap advice ,
NOT crap advice just another option you have made your point clear and I am sure the OP can draw an educated decision based on that.
when you buy dynamat all your paying for is the brand. simple as that tbh
x2 had it professionally fitted before, not much more better if at all then the job I've done myself with cheap materials!!
Also for the above guy moaning about crap advise, it's all down to opinion as I could say your giving out crap advise as I've had it professionally fitted in my old car and now done my own and its just as good so why waste extra money for minimal if any improvements?!
It's opinion if your just going to bitch about someone else advise don't post... Pretty childish tbh
Flashing tape is a cheap alternative to dynamat.
If you want to see how well each one works get a bike bell and add one square inch of each to two seperate bells
i will bet you that both dont ring and if you then take price into consideration and add the same value of each product to the bell you wont even hear a thud with flashing tape as there will be so much more of it for your money.
flashing tape has been used countless times in many installs and the verdict is always the same there is no difference to be heard compaired to the high cost branded option.
a mate of mine did his whole van with flashing tape and it is awsome.
Wow only just checked this thread hah! Thanks for your opinions guys really appreciated! I'm thinking to go with the flashing tape as I'm only on a students budget haha :lol:
