what bulbs do i need for my 6N2?
Basically wanting to upgrade my headlight bulbs to some bright white ones as mine are abit of a dull pissy yellowish coulour and i drive down a few unlit backroads reguarly, also cos bright white looks better haha
My mate bought some of ebay before for his 6N2 and wen he got them they didnt fot so just wonderd what fittment etc do i need? Or if anybody has a link to some they have bought that would be fantastic.. Thanks
  • Replies 9
  • Views 10k
HID Kit Xenon Bulbs h7 35W - Conversion Pair - Slim Ballast Car Light Set HeadLight
http://bit.ly/OG0baa
Edited by Randell6n2blue
As above you could fit hiss, but from experience the 6n2's lights are super glares with they.
Tbh the standard lights should put out plenty of light if they are working correctly. Firstly the lenses are most probably faded and no doubt the reflectors have flaked off leaving white spots, in which case I would advise replacing them as the output will still be sh't even with hid's. Secondly the connectors are prone to corroding, so pull them off and check if they are corroded then clean them up and put back, same with the bulb connectors. The earth pint are also likely to follow suit and are the main reason for dull lights so check and clean these. Then after all these fit some normal h7 bulbs, if they are not brighter then before then there is something wrong.
Personally before I think of fitting his I always get the lights working as they should, then this way you are sure that you need them and if you do then the difference will be a lot more obvious
HTH
Thanks for the replys it wasnt acctially a full HID kit I'm after just upgraded bulbs, but thanks for the reply bout the refelctors etc il take a look
Oh right, in that case then just reference
Dipped beam _ h7 55w
Main beam_ h1 55w
Limelight _ w5w 501
You can run higher wattage bulbs, but I would recommend upgrading the wiring to get the best results
Hth
Sorry to take over the thread, I have the 6n2 GTI and I need to replace the bulbs.
Any recommendations on good bulbs (remember I'm xenon by stock) ?
Thanks.
So what exactly are you trying to replace?
If your xenon anyway then theres no choice of bulb there except another identical xenon one, but if yours are working there shouldn't be a need to replace them
side light with LED's and the main beam bulb with a Osram Nightbreaker or similar.
Ok Osram Nightbreaker but which connection should I get? H7?
GTI -
High Beam - H1
Headlight - D2S (i think)
Sidelight - 501
Fog - H7
Non-GTI
High Beam - H1
Headlight - H7
Sidelight - 501
Fog - H7
Yep the GTI uses either d2s or d2r, but most seller now stock a d2c which fits both. I would recommend changing them if they are a few years old as the light output drops quite a bit over time and the bulbs I use are only £7.99 a pair delivered and I have used at least 30 pairs of these on various cars. I get them off eBay just search d2c then what ever temp so 4300k etc, then sort by cheapest first. They do come from hong kong land so take at least a week.
Also nightbreakers are great but from experience they burn out quick ( but ironically just after the warranty from the seller runs out) in less you have beefed up wiring.
