*** SOLD ***
Mk2 coupe/saloon plastic arch kit.
Very good condition. Includes front splitter.
Apparently can also be made to fit the Mk3 and is a better option than the GT kit if your door strips have been removed. No need for side strips with these.
£30 collected from Leek, Staffs or an extra £10 postage due to size.
Edited by chipsandgravy
  • Replies 13
  • Views 326
Bump. £35 posted anyone?
Hmmm what you mean made to fit mk3 ? Won't they just go on ?
No idea mate. I can only go by what i've been told.
to fit a mk3 u have to cut the front ones where the bumper goes. easy peasy.
These wont line up with the bump strips on a mk3. If you have removed bump strips, these will still have a gap on them where they sit over the bump strip on a mk2 so need to modified either way to fit a mk3
theres no bump strip bit on mk2 arch trims?
The mk3 set has a short extension coming off of the arch about half way up (in line with the bump strip funnily enough). Mk2 ones just sit over the bump strips, so they just have the cut out
I'm really confused. will these fit a mk3 with no side strips and no small arch/sill things at the bottom without too much cutting?
thanks
If you have no bump strips, then you will need to fill the small cut out that the strip fits into. Should be ok without the sill trims but may need to be trimmed where the bumpers are.
Edited by prankstar2003
i fully understand, very tempted .....
Bump. Still got these.
Mine will post some piks when there fitted
Winner! :-D
