How long will my car live for?
Don't want to sound like an open ended question ie for however you maintain it for but...
Is 118k on a mk2 1300 bready alot? And is it worth doing things like bodywork etc for it just to go pop?
Last one did at 80k and was nothing but trouble from the beginning!
Any advice mucho appreciato! :)
  • Replies 20
Stuff wears out, but they don't just die. There's plenty of mk2's about with 150-200k on.
As long as its looked after, it should be good for ages :)
Keep it maintained/serviced and it will go on for many more miles.. My dads combo van had 230.000 and still sold that lol
Cool, that fills me with confidence! Its got fsh etc an only a couple of owners. Runs better than any mk2 I've had tbh!
Is it worth some preventative measures like replacing certian things before they go?
It'll get serviced, plugs leads, arm and cap etc as soon as the new tank is on
Earlier VW petrol engines are generally pretty bulletproof providing they're maintained.
I remember by dad used to have a passat 1.8 8v estate years ago, complete workhorse, towing race cars on trailers, always full of stuff etc...that had 280,000 on the clock when he sold it, on the original engine..used to run on fumes that thing I swear.
Do you know when the cambelt was done?
Some spark plugs are meant to be good for 100,000 miles now...but thats with accurate fuel injection systems on modern cars, but they do last..
IMO regular oil and filter services and allowing it to warm up properly are the best two things for engine longevity.
lets face it if the engine dies its a perfect excuse to afh it 8-)
Thanks for the info! It will be serviced etc every 3k or so and always driven with care, not worth trying to drive a slow car fast it just makes you look a douche bag!
Cambelt was done a couple of miles ago, waterpump was not however.
118 is nothing
the sparkplugs that are 3 prong single electrode i have been useing a set since 2006 and have done over 60,000 miles on them the round centre electrode is not round anymore tho its 3 sides worn down quite a bit
118,000 on a 1.3 L carb vw engine there BOMB proof
should do over 200,000- 250,000 miles no problems as long as its serviced and looked after :-D
Edited by g40dabbsy
Cheers guys! Looking promising then! My last engine (1300 mh) is bolloxed though at only 80k. Loads spent and never thrashed, must've been a friday afternoon job!
They can suffer a lot more from not being used enough.
^^ Yep. If left standing for long periods they can lose compression, things tend to perish too. 118,000 is nothing.
I'll just leave this here
Nick made a good point about letting it warm up before giving it death
Was stood for 5 years! Shit.
My brothers has a mk1 Golf 1.1 (same "small block" engine as used in Polo's)
The original engine was still going at around 220,000 miles
A lot of it is doing preventative things rather than waiting for things to break then changing them.
8-)8-)8-)
My mk1s gearbox gave up at 195k. Smokey mofo of an engine was still going well! Unfortunately I wasn't experienced enough to know how to change the gearbox/re-ring the engine at the time :-( Otherwise it might still be running!
mines on around 190k...engine has been fine with regular services , had a head gasket due to the common oil leak
4speed box was replaced at about 140 due to being really noisey but it still worked
