Woudln't normally ask..
http://www.clubpolo.co.uk/forum/index.php?...=272628&hl=
Worthwhile having a read of Chris' guide for anyone thinking of turbo-charging a small block Polo motor. Chris' AAV turbo does a fair amount of miles, returns ~45mpg (think he said he'd hit 48mpg- although he drives like a granny... :-p ) and it makes 173bhp on full boost.
'Budget' build at £2k... but it's reliable and has stood the test of time.
  • Replies 117
  • Views 3.9k
or just buy a PY engine for £50
them AAVs are getting real expensive :lol:
Have read it, several times and have been in contact with Chris too.
Or just bolt on bike carbs, cause they're so easy to tune...
Oh no, wait.
Lol yoof you can't just bolt bike carbs on, most peoples fall off because they ignore advice of how to make manifolds
Gentlemen, if we could keep the comments constructive please
Dam, you got me.
I'll just look for some fucks to give...
:lol:
Diesel- yeah that would be interesting, but there’s a fair amount of custom parts involved in making a 1W give big power (Check the one on Club G40) and if you’re going to be buying hybrid turbos etc for one, then why not buy it for something with more than 130bhp?
i've only ever skim read part of that build so not sure what spec he ended up with but i can't see what you couldn't get decent power from one just building it out of scrap yard parts, might not get 130bhp but 100bhp with a shed load of torques would be fun in a early polo imo
if i was building one i'd look into fucking the standard pump off and mount a bosch turbo pump on the drivers side of the engine, either using the cam belt to drive it or (more likely) attach the original diesel pump cam pulley to the cam pulley (so two pulleys at one end instead of one at either end) and run a separate belt from that to the pump. once you have that fitted you are opening up a whole new world of tunability, bigger plungers fit off other cars, all the common golf td mods can be done (fuck off the governor ect) plus you get all the boost enrichment shit.
i don't see any need for hybrid turbo's either, there are so many you could rob from other cars there would be one to suit your needs available for next to nowt
Edited by Mclovin
How come you've not gone for a diesel in your mk2 then guy?
Si, are you going to conclude the engine that you've got in the mk2 at the moment then? Honestly, bolting on a set of bike carbs and getting them running was pretty effortless, so there's no reason why you shouldnt get the same results. It would be nice to get that sorted, whilst building the next stage engine.
I knocked up a shit manifold, fitted the carbs, wired and plumbed them in, set the idle/ignition in about a week. That was a few nights in week, then saturday morning. This was to get it to santapod for GTI fest, where after a few tweaks with the slides/springs and mains it was something like over a second faster than the others in its class. The only problem i had was because i bought some pretty over engineer'd jubilee clips that were too fat, the carbs were being pushed off. Fitted some thin clips and they never came off again.
If me, nick and eric can do it, you should have no problem.
Once you've got the AEE running well, you could then maybe transfer the knowledge over to a lump.
EDIT: Oops, forgot to add. Seen as though this thread is for our opinion on what we think is best. Id definetly go for the ABD-T if it was me, sell the other blocks (isit 1W and PY you have?) as these dont offer any imediate advantage and you'll re-coop a lot more funds from these than you would ABD, tommo prooved that you don't need to spend all your money on a FI engine to get results. Yeah he had the knowledge and the craftsmenship to complete the work to a high standard, but you've got plenty of time to do your research into the parts of the project you doubt yourself, and if you dont know anyone capeable of carrying out the machining, dont hesitate to contact me.
Edited by MaxGT
Ehem .. even i got my car running ;)
The AEA will be completed and tun for a year or so. I'll continue with that engine so no knocking it on the head, but I'm always looking what to do next. I have the luxury of time for the other engine, but I could do with recouping some of the money. I'm never going to get round to fitting both lumps, so I may as well be rid of one.
The machining work is all done, I have Tommos actual pistons and crank. All skimmed an lightened. I bought them from Saf about a year ago. I also have the ABD block, GK inlet, R5T carb, dump valve, front mount IC, T25 turbo with manifold along with the mech head. Bar the small details, most of the big stuff is here.
The 1W is also complete, with a knackered pump. But I have a spare pump to go on so once that was swapped over, it'd practically be ready to go too. The t25 manifold and turbo would be used on that egine too.
PY was sold in the summer, so I no longer have that. I do have 2 standard 1.3 engines though. One complete, the other missing a few head components
Id go for the abd! Would look great and sound awesome.
Get it built up and run it outside of the car or somethin?
Ah thats cool then, you shouldn't need to spend any more money!
By the way, i've got all the main parts together ready for my build now, minus the charger. However i'll be using a hyrdo-head, purely because i've got completely rebuilt one sat on my desk at work (been there for about 1 and a half years now), ABD bottom end with skimmed pistons, brand new rings, second set of ZXR400 carbs and designs for a suitable plenum.
However, after reading the thread about the 1L turbo, i'm having second thoughts about the 1400cc bottom end :lol:
So the race is on.
What do you want from the car Simon in terms of driveability, power, reliability and economy? Track or road car? Weekend or daily driver?
Tom got the ABD working, but from memory he said his fuel economy was circa 20-25mpg due to running uber rich for component protection. It didn't rack up a lot of mileage either, so durability isn't proven IMO.
You can use n/a lumps for boost, but I'd not want to put that much through them. AEA/AEE we've seen crack pistons on 15psi, but the Lupo I mapped on ~10psi seems fine so far - albeit not having done many miles and being mapped with conservative ignition timing and on the rich side to aid longevity. The jury's still out on that combo 'til it's done more miles though.
ABD vs PY debate really depends what you're trying to do. For high power/high boost, using the n/a motor is not the way I'd go - with the PY you can optimise the timing and fuelling for power; whereas with the ABD you're going to fuel on the rich side for component protection - thus costing power and negating the capacity advantage. You've then also got the concern over crank/rod/piston strength with the ABD too, as we know the stronger PY items start to suffer above 200bhp.
For lower power outputs, maybe use an n/a engine if that's what you've got. The AAV is proven by Chris Heys to be durable at 10-12psi daily (he doesn't run 15psi all the time), and it's only a few bhp down on a PY turbo K03 due to richer full-throttle fuelling. However, the supporting hardware to make Chris' car reliable; driveable and economical utterly dwarves the cost of a PY lump - so it's hard to argue that it's a financial decision to go AAV over PY.
One to watch might be a black NZ turbo I mapped. It was on machined pistons (Tommo style) to drop it to approx 8.5:1 CR and the owner wanted to run it on higher boost. It's on 17-18psi of boost as the engine builder didn't want us to push it any further, but it's still more boost than Chris' AAV - on arguably weaker pistons. Having said that the CR is lower on the machined NZ, so cylinder pressures might not be that dissimilar between the two cars.
If I was chasing ~170bhp and wanted decent driveability, reliability and economy then Chris Heys' thread pretty much already has the answers for you. If you want to push the power more, I'd use a PY block. If you want to be 'different' and can take a punt on reliability, then use the ABD block. If the driveability and economy don't factor so highly but build cost does, look at carbs instead of EFI (assuming you're okay with setting up the carbs!).
For me the diesel doesn't get a look in, unless you're doing it out of interest and would be happy with lower power.
I guess you need to decide on what sort of fuelling/ignition components, and max boost perssures your gonna be running before you make the decision on which way to go?
I'm sure that nz with the machined pistons is the one i saw at ace cafe?
Fuck me did it shift!!!
Yeah, that's the one. Owned by a lad called Pryesh.
TBH I'm happy to run low boost and keep it on carbs/electronic ignition to start with. I know a PY would be better etc. but;
1 - I have sourced most of the difficult parts
2 - I haven't paid as much as I would have for a similar PY based set up
Therefore I would be happy (now lowering standards based upon advice) with circa 140bhp as a starting point. I know I could probably get as much/more from an AFH/AVY hybrid, but it would mean selling what I have and then sourcing everthing else. I'm not sure what a ball park figure for boost pressures would be, but circa 10-12psi should be attainable based upon Chris' experience?
Andy, I have read Chris' thread, but since I dont know the PY or AAV inside out, what 'supporting hardware' does he have?
Think it was at VAG night a couple months back, all the big engine big power cars giving it some through the tunnel, and then u see a tiny polo steaming past haha. Sounded wicked!
Been there, done it. Can't keep doing the same stuff all the time max or it gets boring. I drove and tuned the jetta for nearly 3 years and as fun as it was it was nice to try some thing different with the 16v's, first by running the 1.4 on efi, then progressing to 1.6 and now taking it to probably the final stage i'll go with them and boosting a 1.6. After that I'll probably move on to V8's
As they say, Variety is the spice of life :thumbsup:
aye suppose so.
Thats why i mess about with the 8v engines, theres more room for improvement,. which makes it a lot of fun for me.
No max .. Just two cams seems twice as hard for you :( lol ..
IMO the trouble with boost. Especially turbo, I'd just keep wanging the boost up in excitement, it must be addictive surely?
If I was running a lowish boost modded NA engine I wouldn't be able to resist MOARR BOOST
That's the best thing about a TD, maxing 30psi boost gauges out for joke :lol:
Shame you don't get the sort of performance a petrol running similar boost would tho :-(
If it were me I'd be having a dirty cammed lupo gti lump running stand alone ignition. Then with time you can add throttle bodies and a turbo.
I dont really think turboing G40's reliably is that cheap. Bits and bobs like intercoolers, pipework,cams etc start to stack the build costs up. Although for the amount of power from such a small capacity, it is an achievement when 200 bhp is reached. But then again, I've got a full rebuild on my hands after 200 miles!
Edited by etches69
