Woudln't normally ask..
So we are all agreed that a AAV engine running drilled pistons with a Ko3 on Bike Carbs is the way to go?
  • Replies 117
  • Views 3.9k
Not agreed yet :) my 2p...
Andy makes a good point here RE: AAV Vs G40 cost when turboing. There really isn't much financial gain to be had by using an AAV - for example, the saving from using an off the shelf G40 map vs custom map for the AAV offsets some of that cost if you went with G40 management.
For me, I wanted to keep the current engine. I was interested to do something a little different and Tommo had shown the non-G40 blocks could handle boost if done properly. More or less everything else for the AAV build had been done before by the turbo G40 chaps - Andy, Yoof, Hayesey etc. I just copied their builds, had a lot of help and advice and bolted it together. By this method the 'supporting hardware' is little different from what you'd find on many G40 turbo conversions - and it's all been tried and tested. Ultimately it was a custom remap from Andy that made it all work and keep working *touch wood*.
As Yoof says, the conversion has the best chance of surviving the miles with me behind the wheel as I have a great deal of mechanical sympathy. The car is used daily for a 74mile round-trip commute, mostly motorway at ~70mph which nets about 42-45mpg. When drafting lorries this has reached 50mpg (the same as with the old SPI) , but damn is it boring.
That's not to say the car is overly nursed - boost has been set to 15psi for the last 10 months and only today turned down as I found it was exceeding the map sensor too often for comfort. I'll often tank it down the motorway to avoid clusterfucks and round the lanes at the weekend but I wouldn't spin up the wheels for example if it can be helped - evidenced by the last set of tyres lasting 40,000mi. The conversion has covered 28,000mi so far.
You could probably get the same or more power on slightly lower boost with the ABD if you wanted - I'm using a standard exhaust, standard throttle body, standard inlet, standard head, not the wildest cam, no aquamist etc which could all be improved upon if you wanted out and out power, especially if this is purely for weekend indulgence and the commute is taken care of with something else. Obviously you might want to up the boost if you use the machined pistons, but ultimately any conversion will only last if it's built and driven within it's limits. If you can justify the expense I'd certainly consider EFI as it's just the tool to get the most out of the car.
Thank you Chris. I have read your build and its testament to the small blocks ability to handle a turbo. Personally I'm not out for massive power, and aquamist etc, isn't the direction I want to go. Even used as a weekend car, I don't want 200bhp in a car that can't handle it. I want a fun car that is making sufficient power in the areas I want. I, like you, am a sympathetic driver so my foot won't be welded to the floor or slammed through the bulkhead. In the end it's a Polo, and unless massive amounts of money and modification are employed huge amounts of power is unmanagable. Even yoofs car is a handful and thats had loads of work done. I don't wan't to go that far. I also want a certain amount of reliability. So people will say buy a G40, its tested. Again, I already have most things needed for and ABDT conversion and for a cost below the usual youd pay for a PY
Bloody hell, I was certain of a 1W diesel this morning, now its ABDT, especially if i can return teh MPG Chris has (I may want to visit Wolfburg with it sometime in the future)
if you're not gonna drive it hard you might as well fit a 1 litre, way i see it if mine blows up i should of built it better :lol:
Thats a fair point, but there's a difference between hard and sprited. I'll likely give it a spirited run :lol:
chassis be fineeeeeeee, if you cant hack the power dont do it haha :)
So hows it going to be fueled at first, and what about ignition? If its a petrol turbo that is.
here here
Max, it will be stnadard ignition with vac retard pot fitted. Fuelling will be with the R5T carb i have :-)
You old boys are power mad. If I want power, I want to know I'm not going curb side. I'd go for a cateram type car for that sort of thing. In fact my dad has one he doesn't use...
People have even said that they can't use the power their cars are putting out on the road,
Id aim for around 160bhp for now, which shouldn't be too hard to get out of the ABDT.
By the way, the R5GTT carb is pretty crap, most are knackered and they're not very easy to work on, from experience.
The good thing is though that you have a boost enrichment circuit, so your safe in that respect, and you can keep fueling accurate off boost,
Unlike say blowing through bike carbs where i'll have to either machine custom needles to drastically increase fuel metering on boost, or run rich all the time via big main jets.
I have a whole load of literature on the solex DIS32 carb you can have, as i no longer need it. I know you like doing things properly and actually reading up/research things before you tackle them.
Thats why I've used the R5T carb, due to its use in a turbo. It has to be the best option bar EFI for now. Would be awesome if you could hook me up with that lit. I'll read whatever I can get my hands on atm if it's going to help. How much did you want for it?
I wanna know how these retard pots work?
From my experience/fucking around, allbeit not much, the mk2 dizzy's advanced arm, will sit at no advanced with no vacuum, at full throttle it has like no vacuum so no advanced, do these advanced/retard ones start the advanced mechanism in the dizzy like half way? so it can go both ways??
Also, max how much did you read into boosting bike carbs? Think you under estimate how much difference that inlet reference to the float bowls makes, people push over 250hp on bikes running SMALLER main jets than standard, its mad.
You can buy turbo needles off the shelf, be a good start point though, need stiffer slide springs id imagine too :)
My car is kinda fun, but its nowhere near fast enough for me now, or exciting enough.
How much do i want for it? :lol:
Nothing?... I'll have to dig it out, i may even be able to scan it and email it you.
I think its a haynes manual sort of thing on the carb that's all. And a few exploded diagrams.
Do you know if tommo rebuilt the carb? I'm sure i read that he made no fueling circuit adjustments, which would explain the poor MPG he received.
Your gonna need a wideband for sure.
The mech dizzy, when under heavy vacuum pulls on the arm. When under no pressure it stays in the 'neutral' position. And when under positive pressure (i.e. boost) it pushes the arm the other way. At least thats how i understand it
I've got one somewhere that i bought of phataz, need to find it!
Do some more reading, the size of that reference pilot tube dictates the change in main jet. So yeah, it adds yet another thing to fuck about with.
As you can imagine, i read up on the subject quite a bit, some guys had to decrease the main size, some increased.
The pressure delta between fuel bowls and inlet needs to stay the same as it does whilst running NA, otherwise the fuel wouldn't be drawn up the needle jet.
I guess its gonna be a case of hooking everything up, starting the engine and seeing where the AFR is at. There's so many variables that you have to contend with, coming up with a base setting for the carbs is gonna be impossible.
Eric. If you want rid of it, let me know. Always good to have spares
Max, scanning would be cool. Or even the actual book/whatever. Would be great, thanx. I didn't ever read Tommo's build I don't think. Certainly read about the car though, Was it on here? And yeah, a wideband needed for sure!
Edited by prankstar2003
But like nicolas says, doesn't the arm rest against the neutral position when under no vacuum? i.e. the presence of positive pressure wouldn't change the position.
Ah so the arm that links the advanced/retard pot to the dizzy internals must be longer than the single advanced type to keep its neautral position in the mid range of the dizzy's advanced mechanism. Simple enough.
Max I wanna do it, just dunno what engine and stuff, and the fact I'm not really allowed to have anything else in garage atm, need to concentrate on other project car
anything but the fear of immanent death is boring :thumbsup:
I've gotta find it first si! But if/when i do ill give you a shout :)
was wondering if anyone had checked this tbh, surely something so simple and obvious wouldnt have been overlooked when people have used them in the past?
Ok, i'll have a look at work tomorrow, its been ages since I looked at it.
He talks about the car in that "supercharger" thread.
well in that case, fucked bushes and high tyre pressures and rock hard springs is the way to go isnt it mate ;) haha, leaky wheel cylinders have a positive effect iv found too :)
