Boot wont open?!
Hi i knocked my rear bumper on my 6n2 and i think the boot locks mechanism has bust. It still makes the noise when you unlock with the key fob but it wont open! What can i do?!! Please help!
  • Views 895
You can remove the interior panel by going in from the rear seats. You need a T25? Torx bit. There's 2 screws - one in each handle, remove these and carefully "peal" off the panel.
You'll be able to see the mechanism and flick it open. The sound of it making noise (the vacuum pump) indicates its working, but not producing enough vacuum to open the lock.
Can you not use the key, actually?
Sorry only just seen this! Thanks very much for your help mate :-) I will have a look as soon as i get some chance but i havnt tried it with the key itself. Will see what i can do but if no good will try your method and let you know. Thanks again buddy :-)
it happened to me aswel , i just took off the trim and theres a little black bit i put back down where the handle has to catch onto ,
Well basically I'm all fixed now thanks to you :-) but.. The. Light on the dash is showing the boot is still open but is flashing on and off! Wheres the switch?
