wet back seats and boot
has anyone come across this problem in their polo 9n ?
I've recently changed my aerial to one of those smaller ones, and took my tail lights off to change the bulbs, now after it rained the other night my back seats and boot are soaked thats all I've done, any other time its been ok, so its got to be something to do with those surely?
I've looked only and people have posted about the seals on the back of the tail lights, I've checked them and they're fine although it did look like water had managed to get inside of it abit?
has anyone else had this problem, how did you fix it?
  • Views 5.3k
tighten all the bolts then get someone spray the car with water from a pipe and check the seals from the inside
bolts as in the twist tight screw on the back of the light? and ill give it a shot in the morning
yeah i had the same issue a while back , My rear light seal came away from the body
And my god , the rear bench was soaked! removed it and dried it in the house
Took it off , Reseated the rubber and tighend the light
- When i broke my old lights i bent the body out a bit so the light sat out a tad
pushed this back in too when i redone the seal
yeh i think this is what i done, my reverse lights stopped working, soi checked my bulbs and must of bent the holes the clips sit in, I've bent them back and its not yet rained again so i dont know if its fixed it or what, do you know where i can get new seals from or whats good to use as a sealant?
