Helllooooo
Hi guys,
Picked up my first Polo yesterday. Here she is:
Not much to look at but only £235 and MOT'd til June so can't complain :-D
My other car's a 1981 VW T25 camper so got this as a winter run around as it has modern comforts such as heating, comfy seats, windscreen demister etc :lol:
It's not without it's problems though so i'm after some advice. The primary problems are there's a rumble from the front wheels, only really noticeable above 30Mph and is louder going round right hand bends (quietens down going left). The previous owner said he thinks the wheel bearing needs tightening as it was recently replaced. If it's been driven like that for any amount of time is the bearing likely to be fooked? Also is it easier to tighten a bearing then it is to replace? I've read it's abit of a ballache to replace the front bearings so hoping i can just tighten without too much agro.
Also the starter motor seems to be slipping. Sometimes the starter will just spin but not turn over the engine and i have to give it a few go's but it eventually works. Replacement starter motor? Seems easy enough to replace and fairly cheap on ebay.
The heating isn't great either. Luke warm i would say. Having a quick look in the engine bay i noticed a metalic flexi pipe at the front of the engine (near radiator) which is torn and loose. Is that where the hot air comes from? If not where should i be looking as i think it's just a loose pipe somewhere.
Cheers all!
Tysoe
  • Views 522
Always worth nipping up the bearing and if it doesn't sort itself out just replace it. Last thing you want is for your wheel to overtake you..
yeh just heard back form the previous owner who said they replaced the bearing and it was fine but then the rumble started so sounds like it's worked loose. Just hope it's not damaged it.
What's the process for tightening it?
