wiring up twin fans?
before anyone asks, this is not for my polo, but for my beemer :)
it previously had a belt driven clutch fan which for space reasons has to be removed. so there is currently nothing there with regards to fan wiring
today at the breakers i picked up a set of twin fans with simple + - connections on each fan
now i am useless at thinking up how to wire things my self, but i can happily follow a simple wiring diagram
but i also want to know, do i need a relay or even 1 relay for each fan? and if so which relays would i need?
i want to wire them both up to a simple manual switch in the dash
could some one answer these questions and draw me up a simple wiring diagram please :)
  • Replies 19
Do you know the rating of each fan?
From that you'll be able to calculate the current draw thus working out what rating relay and switch/wiring you'll need :)
just been outside to check them and nothing is written on them (not thats easily visible without taking them apart)
What did they come from? as I might be able to find the original fuse ratings
a horrid green nissan people carrier :)
petrol engined
i just found this which i think may do the job, minus the temp switch of course
although i still need to know what relays to use?
You'll only need one relay if they don't exceed the rating, but you can get higher current relays anyway. Wired in parallel if one failed the other would still work too.
that enough?
You tell me?
Cant remember what rating the fuse for fans usually are, thought were higher that was all
They are from a nissan almera tino, just did some research :)
Could'nt find the "nasty nissan" listed :lol: but a Range rover fans are protected by 30 amp fuses
A single 30 amp fuse for both fans
So two standard 30a relays wired as drawn above with a 30a fuse in the main live feed to both relays?
Yes, or use those relays I linked before and wired direct to terminal 30 on the relay base with no inline fuse on the feed
What gauage wiring should i use with this setup?
2.5~3.0mm2 should be good for 25~30 amps
What gauge is that?
What gauge is that?
12 AWG
