What do people think of this? Silicone for arches.
Cars coming out of the body shop tomorrow after repairing some dents and a respray. I'm fixing on the GT trim and came across this thread.
http://www.clubpolo.co.uk/forum/index.php?showtopic=206945
Using silicone to fix on your arches? (Mid to bottom of the thread!).
Would it be worth the bother and would it affect the paint if I need to pull them off?
  • Views 975
silicone is bloody strong stuff when used correctly for example fish tanks have a bead of silicone down each side of the glass and they can hold alot of water with no other support once set and last 10 years or more.
It wont affect your paint chemicaly but if you do remove it it might take some paint with it much like any other form of glue if not carefull.
If i was going to do it i would probably use it as its cheap waterproof and relitivley easy to do.
dont put silicone anywhere near your car, i spray cars for work, silicone is my enemy if you have to paint a panel thats had silicone on it you get bad fish eyes in the paint and is a nightmere to get rid of :)
Dude did you misunderstand? I also paint cars, and this thread has no relevance to getting reactions in paint.
Silicone would be fine mate, on my mk3 I've cut the arches so some of the rivit holes are missing, tiger seal done a good job for me! I've had 1 off since, no it wasn't easy but not impossible.
As for damaging the paint getting it off, a tricky task, but i like the arches on so you'll never see any damage if it where to occur !
Nice one guys. Think I'll give it a go to waterproof them around the arches but put it on lightly and use rivets to sequre them properly.
If you're doing it - use the proper stuff, tigerseal or something like, not Homebase mould resistant! :)
