help with the gear box (6n)
just looking for a little advice on the running of my gearbox. iv just got my polo mk 4 v reg. it appear i dont even need to push the gearstick down to move it into reverse this can sometimes cause me to go into reverse instead of first gear and vice versa. I'm worried it causes an accident. I'm wondering if this means ill need a whole gearbox or if that itself can be fixed. my dad seems to think it can be fixed.
if i have to buy a new gearbox what type of gearbox would it be? my brother tells me there are 2 types of gearbox for a polo, does anyone know what type mine would be? its a mk 4 v reg 8v.
  • Views 491
The Reverse gear blocking is done in the gearlever mechanism not the gearbox. By the year of your car it will be a "cable change" setup and to accurately setup the lever you need some VW special tools to get the lever in the correct positions, As to a replacement box when the time comes, a lot will depend on what engine code you have fitted and the code of the box fitted, if you look in the boot area there should be a sticker with the engine & g/box codes on it like this
hey thanks.
