Replacing rear seat release lever
Hope someone can advise on to uncover the rear seats to access the inside to replace the rear seat release lever? It sheered at the top of the stem where it meets the handle part and has dropped inside. getting that is hard enough but will need to get in so I can connect the new stem to the fixing inside. Can't see where to take the back cover off (metal plate) and don't want to tear it off and damage any fixings.
Can't find anything anywhere and some advice (as soon as possible) would be gratefully recieved. Its a 56 IV polo.
Thanks very much in advance
Ollie
  • Views 2.2k
The same thing happened to mine, because we closed the latch while something was between the seat and the side trim.
I did look into it and it seemed as though you can in unhook the lower side near the wheel well and release the lip from the cente part from the bottom. Then maneuver it slightly to unfold the material from the bottom and get your hand in there Although once you have the bottom released you can probably get a screw driver into the latch part and release it then work on it off the car.
Also the model is 9n3 and interior wise is the same as the previous model 9n
Hth
