[VW Polo 9N] Anyone know what this if for in the boot?
i had a water leak in the back of my car due to what i think was the tail lights after i took them off (hopefully thats sorted now). anyways the boot of my car was soaked and after most of it had dried out, abit of my boot had come off and exposed a rubber grommet, does anyone know what its for, theres one the other side too...
I've got pictures below..
5811f7ca3c63607a52de866f9e11f9d26afba5cd
05d94f661337c41b8abf38a1ee447fb9e5e88550
(cant upload pictures at they're just over 1MB)
whats it for?
is there any chance of water getting in from it?
it looked like i had some kind of see through silicone around it, shall i reapply some more to it?
thanks for any replies.
Edited by Cymro
Upload to Photobucket is easier, you just copy over the [img] code
  • Views 6.1k
it is pretty unlikely that water is getting through that. it is probably there as a place where cables could be run though, like when using a town bar for example. the rear lights on the 9n are a common water leak area and will cause the boot area and the rear seats to become rather damp. my wifes 9n had the same prob. wet boot, wet rear seat. removed the rear light, bent the mounting tabs in a bit and refitted the lamp assy. no wet boot or rear seats since.
yeh my back seats and boot were drenched, that was last week and they're still abit wet now. cheers mate
when i had mine it was doing the same found out it was the gromets like the ones pictured but under the spare wheel, there is either 3 or 2 have a check of them mate
ill give them a check when i go out to the car
The grommets are to fill the holes used in manufacture that's what the machines hold and locate the car parts.
I doubt the water is getting in through these as water does not go up ( unless its submerged ) water gets in through door rubbers blocked sunroof drains and under dash drainage that's blocked.
