what seats will change into a mk2f breadvan?
Hi just wondering what seats wil fit into a breadvan i k
now the front seats from mk1-3 golfs go straight in i think but what about the rears the mounts look the same anyway
Any help appreciated
Thanks colm94
  • Views 1.5k
Golf seats don't drop straight in as far as I know?
Corrado or Scirocco (classic) front seats will drop in though, and I think any other rears are gonna need a little modding to fit. Can be done though!
MK1 and 2 golf seats do fit, although mk2s are a little high. There's also a risk of them plowing through your windscreen when tilted, as I found out. Lovely seats though. However, you can swap all the foams over from golf seats to polo frames. If you're after GTI seats, with the better bolsters, you will lose a little support as the polo frames aren't exactly the same. Eric on here did that with my old seats.
Corrado and sciroc seats are really your best bet though as they sit lower down. No rear benches will 'fit' but I ran a golf bench for a while and eric 're-trimmed' his by again, swapping the covers onto a polo rear bench
