TT seats in a 6n2
hi,
has anyone tried fitting a set of TT front seats in a 6n polo,
do i need to adapt my old base plate or weld in some brackets on my chassis to suit the new seats,
if anyone has done this before and has photos,
cheers rik
Easiest way would be cut the audi rails of ad weld the polo 6n ones on
I did it in my lupo and they were spot on
See, are TT seats not a straight swap for MK4 Golf items? If that's the case, then the runner distance is the same, because I've got the MK4 Recaro's in mine..
But you did have to weld the rails right?
If by rail you mean the bit that lets the seat run up and down, then no.
I just welded a bracket that holds the seat down - because I didn't fancy chopping the 6n2 stuff and welding it onto my new Recaros. Could only see that going badly. :p
