bike carbs
is it a very expensive mod to do for this type of engine? does it consume much more fuel and it would be great to hear some feedback from someone who have already done it what carbs are best for the polo 6n2 1.0mpi?
and a posible list to please and if there is a how too would be great seen as i have the head off thought why not ask
  • Replies 9
  • Views 1.4k
No.
Depends.
Good.
400cc or smaller.
See FAQ.
can some post link cheers
Look in engine section.
Oh you'll need to change your throttle pedal to suit a cable throttle
been looking but its kinda hard to find a good wright up just need to know how hard this going to be a need and what is needed
right been doing some reading and so far i have come up with this
make manifold i can do
carbs any 400cc carbs
and cable for throttle
now with the mpi engine is it electronic fuel pump ??
and do i have to change to run on a dizzy or will it run as is with carbs ???
Your main problem is the fact it's a 6n2, which doesn't have a dizzy. Or a throttle pedal you can attach a cable to
so in that case in need a 6n eaither 1.4 or 1.6 donnor car would be better and rip the lot out
Check my build thread.
It's a waste of time. Problem with the 6n2 engines is you can't really mount a dizzy easily.
You'll need to find out how the Motronic ECU controls timing. Looking at putting mine back in coilpack using the ECU, will see.
