Drilling spot welds
I need to replace my front valance as its all bent up (don't ask). I k ow I need to drill the spot welds and I know where they are but is it that easy? I'm guessing I'll need a specific size but not sure what? I'm wanting to get a much info as possible before I go drilling my shell!
Is there an easier way to remove the panel?
  • Replies 15
  • Views 1.2k
Iv got some specific drills at work for different types of welds man
If you don't care about the condition the front valance is I took mine off by removing the wings, cutting from top to bottom between the chassis legs, this gives better access and taking a screw driver and a hammer to the welds.
Yeh, piece of piss with an actual spot weld drill bit
yeah go on ebay simon and search for spot weld drill only about £5 posted and try get an 8mm bit
There's two different types I'm sure?
Iv got ones which kind of look like an end mill then others which are like a small hole saw
the one I've got is basically a flat bottom drill bit with a small point just for centre location
Yeah that's the type that I used to drill out all the spot welds on mine.
I would also get a metal chisel as well as you wont drill out all the spot welds perfectly :)
I used a HSS drill bit, a pass through screw driver and a hammer for this kind of job in the past.
proper spot weld drill ...or you can grind the top layer of metal away so it peels off
Steve, don't really want to cause too much damage if possible as I want to repair and modify the panel I take off if possible.
So do i want one of these
http://www.ebay.co.uk/itm/20PC-HSS-SPOT-WE...=item3f1efcb531
or these
http://www.ebay.co.uk/itm/8-0MM-SPOT-WELD-...=item3a471fed61
Also, is it worth drilling a small pilot with an HSS piece, or just center punch and go with the spot weld drill?
2nd link is what we used at the bodyshop...dont drill a pilot , they have a sharp point in thier center so just start it off and it wont wander about , drill carefully so you only cut away the top skin and dont go through both layers
Which way do I drill from? I'm guessing the 'outside' (i.e. not from the engine bay)? Because I can't see the welds from the outside, I just have a body work manual to go by
yeah the idea is drill from the outside ..if you get it right the panel comes off with holes where the welds were and leaves the underneather panel intact , i expect you will go thru by accident on a few
you should be able to see the welds on the outside , might need cleaning up nice with sandpaper
if you need to fill in any holes , hold a lump of brass or copper behind and plug weld it , the brass wont stick so leaves the back side smooth
i dunno if you can get a new panel , but its quiet a task to remove a panel in good enough condition to reuse it
if you need to msn me let me know..i used to do this for a job
Edited by steveo3002
Cheers steve. I have already bought a new front valance. If i can't re-use the old one, then so be it. May just use it as a tester or something
Welds visible from the front? VW must have been good at hiding them!
yes they're nearly always visable both sides ..how have you cleaned it up? id suggest a wire wheel
it may only be a slight dimple , if the cars a bit rusted or seen some repairs they might be hard to see ......pull a door rubber off too see what they should look like
