Mk3 doors
Hi all may sound a bit silly but can you fit mk2f/3 doors of a coupe saloon or bready on to a mk2 bready without moding them
  • Views 842
Yeah, there's a few minor differences between early and late doors, but they're all interchangable and outwardly the same.
What are the difference Steve?
Mostly bolt on parts and provision for mounting them.
-Addition of side impact bars on the mk3.
-Karl discoverred the other week that there are two sorts of drop glass, one being more curved than the other on the bottom edge, along with a second type of winder mechanism, which uses different mounting points (though the doors generally have both mounting holes).
- There's a revision to the lock mechanism that I won't go into here.
- G40's and some GT's apparently have bonded quarterlights.
- Interior door trim is different.
Correct! My G40 had bonded quarterlights
