how to wire up immobilizer
any one have any idea on how to wire in a immobilizer in .. i need to wire in one from a early type to a new type loom .. and then one from new to old .. as i have put a afh into a arosa . and the arosa engine into the polo .. and use a different ecu and so on .. any help or ideas on what best and easy way to do this ? thanks
.. also have no no dash lights when ignition is turned to the on position also the rev counter doesn't work for the 6 seconds the engine does start and run.
Edited by polodan2010
  • Replies 21
  • Views 4.1k
Could it be that the wiring in the ecu plug isn't exactly the same?
Also do the arosa's not use a crank position sensor and coil pack rather than a dizzy like the 6n? Although I'm guessing not if you have had it running
no the only diffence so far is the immobilizers different dur to different connectors on the wiring loom .. ones round and ones square also the arosa has an extra red wire.
also when i say no .. i mean i thought that there may be one or two pins that are not same so i went and got a ecu and so on that was for that loom aka vw polo and still no joy .. and not the engine as had running ish with 16v ecu and so on on other then was over fuleing and i need it for the arosa lol
Conduct any discussion of car security via PM's please and not in the public domain.
I could understand that if it was "how do I bypass an immobiliser" but this is more of a technical question about how to wire in the standard vw immob. no info on this would help anyone wanting to bypass the immob, if I had that sort of info the last 3 conversions I've done would of been a lot easier :lol:
Thats why I've not locked it, more of a note that if it came down to binning the immob and bypassing it that it should be discussed by PM.
Thing is knowing how to wire it could still help in being able to by-pass it but it would take a pretty determined theif to do that. :lol:
I'm not wanting to steel a car I'm wanting my car to run .. i understand where your coming from all thought even thought been given help nothing has seemed to of worked so to steel a car would take a lot of wiring and undoing dash before moveing .. lol .. still have no running car and there only the one guy mclovin who seems to have a idea of what could be problem ... thanks for all help thought sure can work it out between us and fellow members :)
The only reason I know anything about this is from bodging AFH's into early polo's :lol:
Tbh tho I'm pretty stumped now, I've gotta go shopping in a min but when I get back i'll get a cup of tea on the go and have a think, see if there's something obvious I'm missing :thumbsup:
Edited by Mclovin
haha no worrys thanks a lot bud
you are jeopardising the security of your car by asking pepole how to wire up your immobilizer lol
Why is he? What are they going to do with the info in this thread? The engine will not run without the immobiliser connected and functioning as it should. There is nothing what so ever in this thread that could jeopardise the security of his car
Edited by Mclovin
I've PM'd with the connections for the two types of immobillisers fitted
got your email thanks mate .. also no car still going to have one fitted so some one can try steel it all they like wont get far also fitted with tracker any way more fool them lol .. thanks for help guys il keep you all updated and see if gose to plan .. hope so :) thanks again
if it dose not work some guy has said plug the origanul box back in and so on for the arosa . and get vag com then re code it then set all values to 0 .. and then turn it over and then it sets its self up :S ? dident know you could do this or he talking crap ? any one know anything about this idea ? kinda has to work now as sold polo today so only have arosa now lol
its all up and running and back on the road .. thank you to every one who has helped me :)
Howd u fix it
Fair play mate, how did you sort it in the end?
yellow and white is for ecu .. brown is ground . black is live so the red on new one is the live for it then the black is ignition lights and shit like that on new one .. all done now thought :) thanks again guys ..
Black is ignition ON supply, Red is a constant live supply & Grey/White is the diagnostic to pin 7 of the 16 pin obd socket
Early immobilisers pre 97
pin 1 12v ignition supply BLACK wire
pin 2 ECU WHITE/YELLOW wire
pin 3 Diagnostics GREY/WHITE wire
pin 4 not connected
pin 5 not connected
pin 6 Ground BROWN wire
Post 97
pin 1 12v Live supply RED wire
pin 2 12v Ignition supply BLACK wire
pin 3 Start inhibit relay (Auto box only??) RED/BLACK wire
pin 4 Ground BROWN wire
pin 5 Ground BROWN wire
pin 6 not connected
pin 7 ECU WHITE/YELLOW wire
pin 8 Diagnostics GREY/WHITE wire
well i have red to black then yellow and white to yellow and white and then brown plugged in and it runs have not got the vag com connected cut my hands to bits in small place had to work doing the other wires lol ... but thanks for all your help wouldent of cracked it with out you all :)
