Alpine White GT Genesis
Not much has been happening, waiting for a good time to get everything fitted... though I wasn't happy with the finish on the Mahles, so decided to spray them again, you could still see the dimples from the bead blasting so I used a high build graffiti paint I had leftover from painting my old polo! Then on again with the satin black.
247AB032-EBB3-482E-924E-73F14DFBDD64-290
  • Replies 186
  • Views 20.1k
  • Little bit of catching up, this time for the GT. Plans changed for it, don't use it that much so decided it doesn't need to be comfortable, and this will most likely be its last year on the road. I
  • Uploaded 1 GoPro video so far, this time taking Steven out on the Eastern circuit.
  • Been a while since an update, went in for MOT a couple months ago, failed on brake flexis and a missing exhaust rubber. Ordered some bits while I was away working, surprisingly it started no bo
...bolts and spacers arrived today :) just need to find another 3 centre caps now!
36EBC33B-BE27-420D-877F-FF3EA0627076-290
E7229EA6-CCA1-4DCD-AF59-2DBC217AC3FB-290
sexual! love mahles
Got a start on it today! Got all springs/shocks fitted, but ran out of time so will finish tomorrow, here's heaps of photos...
FCF18AFE-30CC-46E7-8661-431F89822946-470
12E9B47E-635D-4346-B85E-149E78155905-470
7DF87E1E-BF1E-40E4-A213-0DFE52869772-470
C1C4C873-2068-4997-8912-178A12C3D513-471
8F664366-7457-4162-BA81-66566A63A6D0-469
Second top notch on the rears, will see how it sits once the other wheels are on.
C1ECC640-C5D7-4D79-A306-56D82C379118-472
1496F835-F0D1-43CD-95F3-E339887AB577-472
2F3C141C-B571-4175-96A0-4E10434B7B61-470
527CA342-6805-4BBD-A2B4-314C05E79236-468
The magic spring compressor thing!
45A6142C-08CE-4B05-B557-83EC4E2A1255-469
488D85D6-037A-4FF1-9FD7-4AC84FA61A22-468
6DD954BC-6CBB-4153-AA3A-8BC93CEDC600-468
Edited by citrus
Another busy day :) more photos...
Discs were a bit past it
b572bdedf1a4555c3f66bdad1236cdfa_zps4c4d
New discs on
5e6987baae038b373c46bf8b977a06a8_zps6796
Started service
c9b90ce0ac2378b216f9e197210c7dd9_zpsaa0b
Filter matches the wheels!
b499616a13133a3a4ab6ab23259fdb5a_zps4bcb
Getting tyres fitted
de36ad1b735f731480e25b3a8deebbd9_zps6362
42b33bd4558c8a4e41a519effc909387_zpsbd96
Only just
a3d89715db3a2181f09180084b534efb_zps8a84
4da44e2cd7ea9ceb1a419d55f66ba9ff_zps401a
1368e6351c41239156fcf50bbe14df11_zps908c
71ae6a28c7251181597a9c4a90991f63_zps403e
Maybe get some decent pics tomorrow, after a well needed wash...
Edited by citrus
Nice and cloudy day for some photos...
would be epic with silver wheels and a little more lower!
WANT THOSE WHEELS
  • 5 months later...
Thought I'd try get some photos, now that its as low as i can get it without coilovers.
Although there are some issues now!
On the passenger side, the drive shaft hits off the chassis leg.
On the driver side, the steering arm hits the brake servo.
So current set up is
Front- 1 coil off 80mm kit and lowering top caps, 20mm of bump stop
Rear- passenger side has 2 notches left, driver side has 3, and 1.5 degrees negative camber.
Edited by citrus
I like that last pic :D
one cool looking polo you have there.
good set of pictures there!
Bit of an update, been doing a lot of respraying, in a car park with aerosol cans...
Also a pic of the lowering top caps, which still bind a bit.
cb5788f67d190c7c65074338f0d6b6c3_zps28bb
The rust.
9D44B680-9466-4D37-838C-F68B299E3A4E-186
4EB3D87F-3FE1-4A86-A847-F03DF602001A-186
Still to flat it back and polish.
4F5AEEEF-10A4-4885-9D3B-783BA7C59225-200
Wheels also got more black and lacquer.
DB6D8D1B-22F3-457C-AFEB-6A4BAFCF56D9-263
Then polished.
d35dba24fec8b7a431ae723360dbb474_zpsa513
32fcf6ab797594ce5cf7b03e168556b6_zps1379
Aim to get the car done today, then get some photos of it all together again, at some point...
Id spray insides different colours and then the faces leave standard!
Just a few more recent photos, Mahles are off for a while, thinking of spraying the inside barrel red over winter.
f2f7d15017d615b799e8d4946ac5d563_zpsd837
ac0ba95391cb4fc767dfc9d7148c5c27_zps5455
Find the polo...
Fingers crossed for lots of snow!
8F5AC355-BE66-4B5B-8E27-CBABE440E08F-145
D8D0A378-B599-499D-874D-6B2CA949C502-145
Looks a bit funny on the back with the camber and no spacers, need some longer radius bolts.
Edited by citrus
That looks mint! :nod: Never, EVER thought a white grille would work but you've pulled it off haha!
Some slight progress for when spring arrives, picked up some Zender Turbos, 15x7 et20.
So had to try them on, at night... with 15mm spacers on back.
I'm thinking 165/50/15's will be needed.
Seems like pepperpot caps might fit :)
FC420D5F-BB10-4076-BBC3-B39F7F433E24-265
3071EE9B-23AE-41EB-BBA6-4F95E6433C1F-265
E9428DB8-6481-47E3-ACD9-26CD4EE3DA61-265
DE12B9CB-8EC2-4809-9A07-112CCF48FC9E-265
White grill is spot on! Love the new wheels!
looks mad mate! was wondering what springs did you put on? and how low did you go?
and you dont still have your bump gards do you? I'm missing one on the drivers side door
It's currently on a Philj 80/60 kit, with 1 coil off the fronts, 10mm of rubber bump stop, lowering upper spring seats and 6n top caps.
It drives ok considering there's about 15mm of travel, will need to see how it sits with the Zenders on.
The upper spring seats are a little deformed and stuck below the threads, plus the passenger side front shock is a bit past it.
Probably been about 8 months / 5k miles on the budget kit...
i love this car man, looks so good, gives me some inspiration!
Couple posts from another forum to update :)
Bit more tidying up done today, rear arches and bottom of drivers door had rusted a lot more in the last couple of months.
So attacked them with a flap disk on the grinder, buzzed it right off with ease.
Got Greg up early today to have a go of his paint booth, thanks again!
65950074-CAC0-44D8-A949-3845FE224D86-277
366336C6-1F80-4BEC-9F4C-27A48BCD4782-277
9F03A761-F108-4297-BF2E-691350DC2EED-277
0F37839D-38BD-4CB2-B701-6D304ADD33D0-277
EF073D3E-652D-4755-8025-B957CACB655F-277
Excuse my horrendous masking skills.
Also my filler wasn't that great but came out good enough.
Got impatient waiting to paint the zenders, had most of a can of satin back, and a dry morning for once.
So 5 coats, heat gunned in between, then rubbed the flat faces with paint renovator then polished.
Came out pretty good, my addiction to black wheels continues...
C0257497-3D74-48E0-B591-AB2E8C88D408-596
Those Zender Turbos look sweet!!
They a rare wheel?
So had a bit of a wheel related adventure today.
Ordered tyres yesterday, went to get fitted this afternoon.
They are 165/50/15 Bridgestone Potenza's.
first garage had one attempt of seating the beads, then they gave up.
Went to a nother garage along the road and with the aid of an air cheeta thing, went on no bother :)
Though there are a few marks needing touched up now but at least they are on :(
Got home and it had stopped raining, so had to check fitment, soon as I jacked up the car it started raining again...
Couldn't be happier with how they sit, that's with the 15mm spacers on the back.
Before they go back on, I've still got 3 centre caps to finish, got to remove the camber shims, and probably fit some ARB blocks to centre the front wheel, should really get the wheel alignment done after too as it hasn't been done since it was lowered...
Lots of iphone photos as usual...
B1883716-9D5C-4130-A7F0-6D781948E88C-885
A0BDF2A2-7694-4F8C-BB76-65D0EC1D8BE9-885
E95320A7-D764-4810-94E7-EEE5E15008A8-885
AA535A84-AB23-4688-ADE4-C72812F25B65-885
BFAAEEBE-DDDE-409C-8705-A74BED0E157E-885
A546514B-7A83-4104-B285-2ACC9730D6B7-885
0B2AAF31-80B1-405A-B534-2631BA617C32-885
55FBF99D-8809-4259-9312-2DF06F2BA842-885
220BADAA-815A-4F14-ADF2-EEFE8614F805-885
3FDCFAC9-7028-4A04-9A2C-4BCE7DCE57CE-885
75821DFE-BCB4-4E01-AA91-8016DEEC96E5-885
0A935393-0205-4CBB-92AA-227157D8537C-885
I think they look mint... A G40 I owned years circa 2008/9
Edited by Jake
