Alpine White GT Genesis
  • Replies 186
  • Views 20.1k
  • Little bit of catching up, this time for the GT. Plans changed for it, don't use it that much so decided it doesn't need to be comfortable, and this will most likely be its last year on the road. I
  • Uploaded 1 GoPro video so far, this time taking Steven out on the Eastern circuit.
  • Been a while since an update, went in for MOT a couple months ago, failed on brake flexis and a missing exhaust rubber. Ordered some bits while I was away working, surprisingly it started no bo
Started collecting parts for the suspension/brakes overhaul. Hoping to have all the bits by spring!
Got a G40 rear beam, with built in ARB. Going to build up a rear disk conversion onto it.
Nice and rusty.
93b39a85f0166c6a7b9c732f84ba2b24_zps57f7
Drums got binned.
38d988ee23ce06b92dc59564ac832ca7_zps5624
Wire wheeled and first coat of black, got some thick paint to brush on.
ae979581e93e7d53ab65d3cafd109fb9_zpsfaa0
...and figured out what was causing the knocking on the passenger side,
The "lowering top cap" had cracked all around the centre, and the 2p's holding the insert tight had squished so were replaced!
Top mounts are still knocking, but only takes a week from new, so looking into some adjustable alloy ones from Germany.
E3C7DD7F-9967-46EB-8479-A21661B40CD9-231
Lovely polo.
Slight delay to the plans of rear discs, front upgrade needs to come first.
So for the moment, the drums off the G40 rear beam were dug out the bin and cleaned up.
Still need nylon bushes but its done for now.
New bearings and cables, and a whole lot of cleaning later...
6B2D386B-E819-49C1-A3ED-898310400FE5-329
1DB4ADBE-0441-46B6-BB9F-DBC69108A27B-329
MOT in a month, booked a week off work before it to check everything!
MOT was today, failed on rear brake pipe corrosion, but it's booked in in a week to get them all replaced.
So the strip down has started, everything I need off except gearbox, flywheel, inlet and throttle body.
The list for the next week is...
G40/GT rear axle and drum brakes
GT inlet manifold
VW11 brakes and Black Diamond discs/pads
Lightened flywheel, from ClubG40
LUK clutch, 200mm ABF
Oil change
Coolant change
Paint everything that's going back on
And maybe re-paint engine, gearbox and all the other little things I missed.
Should keep me busy for a while!
What do people think about underseal? Or should I just wire wheel the rough bits and touch up.
Too many photos as usual...
1634ad761cd634975642ca7a80669661_zps6fd6
7EE2D7D9-EB5C-4EB1-A683-6480FF88ABD4-731
F70827A1-4744-42DA-8BF2-C6C062F75735-731
1F3CDD27-648A-460F-BA8C-7AB771D0820A-731
AE72B97A-2851-4E5F-91C3-A3C771C0F895-731
DC20801D-388F-4DD5-9F8D-D795BA320F58-731
53314F56-1C1C-4585-91D6-48015D2E407C-731
776DB87A-E082-4763-892D-3AAEDA627455-731
FC970E32-1132-48CA-B3CA-A8B02D585C21-731
966C8488-FDDA-4578-9D38-59FBF1837BA3-731
B77A6F50-41E8-452E-9E18-36C31F9AB45B-731
626409F3-DF35-4F7D-BA03-4E2ED44176E7-731
1B63D051-369C-4759-B7C0-5AC4913EF163-731
Can't beat some roadside mechanics.
Give me a shout if you're needing a hand. :smile:
The to do list has started growing, found a fuel tank online last night for a decent price, so that came out today.
Also now need to replace a front wheel bearing.
But still got a lot of cleaning and painting done.
4C0EBF4A-B3B6-4AD1-96CE-A8D30A6A3EF0-911
2B2D5D6D-3DF3-4EB6-A68B-45D6C5E379F0-911
BE6FE431-615B-461D-8056-1C3C08ECF519-911
It was dark at 19:00!
8950B5A5-3238-46CB-AA17-165ED6DCCCA3-911
51CE8B36-4966-42C5-B4FA-DCD4D95ABB5B-911
...worn out already, 5 days to get it done.
haha some true dedication going on here bringing it indoors too. loving this so far, little bit different to the usual is always good, keep up the top work
Nothing exciting happened today, but I'll stick up some photos to the collection :)
With the aid of sledge hammer, an angle grinder and a vice, the front wheel bearing is done. It's a cheap one but should last as long as the paint on the struts.
And a whole lot of lying on my back scrubbing, came out ok though.
Got a few patches to touch up and have some new white stonechip for the arches.
What's left of the inner race.
D13848D9-2F74-4158-B5D1-B03F6B047EB1-108
ED750A7A-A8C3-409E-9257-7A66516DC048-108
3C180776-3EB4-499C-A535-C71F3BC28C8D-108
3009F3C6-3BE6-470C-8D7E-7A166AB526FE-108
Half done
70595014-E53D-46E2-A3D9-93E5D6FB8FB8-108
B846D27B-A0C3-48BF-814A-8CE77E5F9AA1-108
B1E65E4A-1727-4D30-8A16-D066AB388F04-108
373D3AE1-0C50-4EC4-B16E-9A39F6367068-108
7015B5AC-5DB8-4C3E-98EF-ADD01A88CC94-108
17FBDF02-4765-43EF-A898-6928A0DDBE7C-108
From behind the arch liner
A4573240-70C9-4DE2-A344-90749036F959-108
That is super clean underneath
Half-day update now that I'm inside drying...
Test fitted the brakes last night, mk1 golf carrier hit the inside of the rim by a fair bit, so cleaned and painted the VW1 carriers.
Built up the cheapo gazebo, a whole roll of electrical tape to hold it together.
And started roughing up the inner arches then painting. Done a few odd spots underneath that needed attention.
Was still wet, pretty rough compared to he other ones though.
241FBEE9-059E-4196-BDC3-0A4476C56DBB-124
Not easy on you own.
753FCCF6-4C8D-4BC5-A1BA-F49F7F25F83B-124
Good to go.
6CDEA8FF-3A82-4DDF-9F36-D8D4E165E9EB-124
8FFE4E9D-D72B-4124-86C4-87B6C8E16F7A-124
E1DA77CB-C8D6-4999-A4C4-302C243B43D7-124
E815E8F2-ECB7-4281-8F90-082B25D243A5-124
Will be left to dry for a day then I'll spray on the stonechip.
Plan to get the suspension bits built back up soon.
Still waiting on fuel tank and nylon rear axle bushes to arrive...
Couldn't put this off any longer.
Was a right pain but its done now.
Flywheel, clutch and release bearing changed.
67543A2D-9A83-49C0-BC9A-92DF352BE92E-140
B0963624-327D-4A3D-8FA6-3E53312D6B8B-140
Old one
5A1FA222-0E9B-48D5-9089-809CC21A34B1-140
510EF025-E0E7-4B0E-9435-9CCA1E8F109E-140
3B0B8020-A91D-4496-9377-509578931634-140
1E46AE4E-806C-4AA3-923B-09709438E69A-140
Bit of a lazy day today, the stone chip didn't get on well with the hammerite on a test so I just done another coat of white.
Also put the arch liners and bumpers back on.
The inlet manifold was swapped over, throttle body is out for de-wedging.
7194A03C-D69F-4C5A-8413-F468DDF54AD4-177
A01BE09C-F045-4E1E-AE7E-72669A4A6361-177
E6EDED7D-9405-45FF-B70B-6057AFBB6E6A-177
8CD94D1C-944A-4336-9B7A-78B35ED14047-177
2248170F-771A-4C66-B4D8-03C31F1EC346-177
8E86514C-66E1-4790-B8BA-EB0C5D6BD8C0-177
Will sand it smooth once dry.
Today's wet events...
Put the front half of the exhaust back on, throttle body etc.
And the front struts, brakes and ARB.
95DFDDBF-3789-4071-BA85-7320F399642E-188
ACCA4082-07C3-4884-96DD-B4D2E8D34CE9-188
8BCEDD63-1ACA-4482-9EA7-6796A29561F1-188
It was dark by the time I'd wrestled the ARB on and bolted everything up.
Nylon rear axle bushes will not be here in time, so the old ones will be going on for now.
And I'm giving it until lunch time tomorrow for the fuel tank to arrive, if not the old one will go back on :(
I'm all wrinkly from today, lying in the gutter...
Fuel tank still hasn't arrived, ordered last Wednesday from ECP :(
So the old one went back on.
Then the old rear axle bushes went back in, and that got fitted.
Then the back half of the exhaust went on.
I'd borrowed a vacuum brake bleeding kit so I had an attempt at bleeding the brakes. Not the best but should get me to Inverurie tomorrow morning for the brake lines and MOT re-test.
Not looking forward to taking the fuel tank and rear axle off again, but at least it's back on the road.
04047060-AECF-4E61-A341-F7601A96DB9A-216
9B2E8DAF-2EE4-4A33-9CE0-1FA95576A52A-216
591825F0-C21E-4582-92FA-6DFF8F758ABA-216
Old rusty fuel tank in a nice clean space...
0BAF74F8-EF17-4E92-B22A-C8B09251D186-216
41D91A01-C420-4224-A5D8-9D617ED73A60-216
Snap!
2B5E9606-D797-430A-881E-6720E158FDD6-216
Replaced them both.
4DBA6852-9E1D-4CE3-B2BC-450B4CC54E9B-216
Proof that its a car again.
9B30B08B-99B5-45EB-A831-7826F00B8147-216
well done mate, shame about the fuel tank, starting ti get very clean inside and out this, I love it
Just in case anyone's wondering, if you order online from eurocarparts, and they make an attempt to deliver, they don't leave a card or call.
Fuel tank had 2 attempts at delivery, must of been in the 1 hour each day I took the wife to work. No cards, phone call, nothing.
Called up today to ask, at my front door 20 minutes later so not all bad.
Now to slap on heaps of paint and leave it in a corner until its a nice day...
19F37A5E-43C6-435A-840E-47518E36C104-237
Collected pretty much every bit of polo plastic/ trim there is today from Tav, and also a set of front scirocco seats, haven't driven yet but sitting in them feels a lot better.
Got some of it fitted earlier, what's been swapped so far is...
Glove box lid
Centre console without speaker holes
12v plug and tray
Black sun visors, sun roof handle, and an extra handle for the passenger side, plan to paint the roof lining in black plasti dip at some point.
Rear bumper with un-broken clips
Number plate plinth
Seat belt bolt cover
Clear front indicators
Smoked side repeaters
Late spec tinted rear lights
Thick boot carpet
Front carpet with no rips
Stereo blanking plate, will be going in the glove box at some point, the bright light is annoying me and I only really use my phone for music anyway.
Still to be fitted is...
Front bumper, a lot less scuffed than mine
Full arch trim set
Front speaker covers
Air filter cold air feed
Side boot carpet
Handbrake lever with working button
Hole free rear door cards
That's all I can remember.
Surprising how much will fit in the back of a polo!
4A3B6C72-DB75-4019-BEFF-2C6CB1234C61_zps
DEBDD7A7-28E6-4992-B886-375C505C81C4_zps
F4FB1DD9-60C8-4164-9B28-0B035B2DE1EC_zps
3B042B9A-2E22-41A0-BE98-47D399CB1A58_zps
1D0A2473-CE4D-4418-9896-340F084E8336_zps
Need to think of something to do with the old seats.
52CDF1D4-F4C6-4F8D-9015-8E7343CBAF8E_zps
Love this so much!
Really good progess mate, must have really good motivation to get it done!
That's looking awesome mate. Do the scirocco seats fit straight in (on the original runners?) if so I'm well happy as a mate might be getting one to break soon :-)
Yup straight fit, they are a bit tight width wise, one side touches the door pocket and there's just enough room to get into the handbrake.
Been a while since an update, and took a few photos from the recent unfortunate event...
22E44985-8B85-4875-B244-161C4507A479_zps
CCD5538F-B4D0-44C8-B985-02DD5DC1F634_zps
EFE0E2A2-9EE3-456B-B34C-09E63B165F56_zps
Been stocking up on suspension/ steering parts and bushes for a re-fresh in spring, back to 60/40 drop and standard size tyres. This low car thing is getting annoying.
Lovin this mate. It's kind of an inspiration for my new white coupe cl ;) think I'm gonna go 60/40, but don't want a harsh ride.....trying to decide which kit is best (on a budget) ;)
