Alpine White GT Genesis
Why is a valve in a drill? Did you do that to polish the faces up?
  • Replies 186
  • Views 19.8k
  • Little bit of catching up, this time for the GT. Plans changed for it, don't use it that much so decided it doesn't need to be comfortable, and this will most likely be its last year on the road. I
  • Uploaded 1 GoPro video so far, this time taking Steven out on the Eastern circuit.
  • Been a while since an update, went in for MOT a couple months ago, failed on brake flexis and a missing exhaust rubber. Ordered some bits while I was away working, surprisingly it started no bo
Yeh there was a lot of crust on them, used a foam sanding pad and some grinding paste.
Edited by citrus
Got to work on the head, lapped in the valves, got it skimmed (at Aberdeen head shop) then painted with the same POR15 engine enamel. Fitted the windage tray and sump. Have some valve stem seals to fit the I'll put it all back together. Needing a torque wrench before I fit the metal head gasket, cam etc.
9EEC9BF9-FDFC-4A8F-A51B-63554D78573A_zps
342F186D-0326-478B-9D0C-78578EC3FB28_zps
3C6CFE1D-647A-4B06-B32F-0AD6780DA492_zps
874E2D77-B1AA-49D0-B01D-B435716E3063_zps
6DA7904A-3ED7-4630-8664-92E3FED48712_zps
80665D9A-7434-4671-8993-C24FFEB91A89_zps
E2782847-2DE2-4AB4-B16F-E11121FD50C5_zps
AEFBEDA8-BA32-4218-A079-C38A5A4966DB_zps
And some arches came, so had to have a trial fit.
EEAB47D6-54B1-4D2B-9EC9-C395A164FE4F_zps
B44EF169-B668-4DA7-AE20-92714657894E_zps
920801A4-80E2-4A88-AC60-974225C6CD70_zps
C78FFB2E-4217-4126-8EAD-27A89212D4E9_zps
55B21AE3-04ED-44C7-9543-DABE9D5BB047_zps
Will need a fair bit of arch and bumper trimming to fit.
Edited by citrus
Did you get new guides or was it within tolerance? Good work on the head...I have to do the same soon too. Probably after Xmas though
Loving that you got those arches too, its gunna look like a monster
The guides seemed OK. The valves were out the other head.
Also realised the front arches are on the wrong sides in the first trial fit, there's a lip for attaching a splitter, must be for the mk1 kits.
Now it has the arches I would definitley say you need a diffuser for the full on look [emoji14]
Interior came out, and so did the angle grinder...
7A641B50-6983-43DD-B43B-08CB8EF566DA_zps
3A760585-E049-4A90-8F61-134CFB180D86_zps
Bought some sheet steel, 1mm I think.
D2BBF4DB-C6A3-4216-A9CA-6A8D0AF719C0_zps
E7574D2B-917E-4F28-9C38-431C93983C59_zps
0283838B-5B46-4C8B-957F-60E3AE56BCB5_zps
E11339A0-F2C3-4FE3-96EA-936D0D6EA92C_zps
Sealed and riveted in.
F4157693-55D3-4432-8690-368D547782B4_zps
Painted.
989475FC-EBE5-4764-8264-30B66B5C0B17_zps
FC28D7F8-93D3-4F40-B9BC-92342AF8386C_zps
C058364D-1BD5-40A8-8F63-3D7CD7ED7431_zps
Holey bumper on, and while number plate strip for a week or so.
E85AE91F-DB11-4014-90D5-9DFFAD24FBAF_zps
And recently the brakes were looking a bit past their best, a rear line started leaking at the connection.
Squeezed it in the garage.
E84BB3A4-B568-4970-942D-C5755FCB8300_zps
9B835101-FD4E-45FD-A5C2-7424C7C0AFBA_zps
So stocked up on parts, standard disks, and decided to try some Ferodo DS2500 pads after reading good reviews.
5705EF35-DEDE-4066-834E-E93862D92D07_zps
Cleared some space and took off the old lines.
1AEAFE80-ACC8-4CC6-A2C8-CE63AA833668_zps
New lines on and a 4 port 20mm master cylinder.
C2281109-8902-4623-8B98-C20357100FA2_zps
Starting to look a little crusty under here.
F0E0A919-009F-4239-B5B5-B21E61D87561_zps
While it was on axle stands, decided to adjust the damping on the front a little firmer, which ment taking the struts off, trimmed the bump stops a little too. And lowered the back a couple notches.
69BE2BC5-8096-4E70-80D7-BCB8B8FD95BF_zps
Brakes back on.
72C5D916-6762-4745-92C1-6FF9848093EB_zps
More holes in things.
58CAD625-6E2E-495F-BBB2-F6AE0B8AA4BF_zps
Holey front bumper on, cut a letterbox out of the bumper bar too.
D53A2CB6-9003-43C2-A45A-9603410BA7DE_zps
0E49845F-25C0-4812-B016-224120469C74_zps
A couple of black seats.
EA6CB4BE-CACA-49CF-B4FC-1A0A32479CA6_zps
Another view of the back.
1C462578-EA6E-44BF-8089-6E0BD85D1891_zps
Bled the brakes then rolled it out and done some skids.
257D8189-4E3B-4D8E-BDF6-8C7F9D0A13F2_zps
ABAC85AD-CAC9-4602-807E-327DFB894598_zps
F12CE64C-B885-4059-ADF9-820EAA183E90_zps
9D248C34-3D5C-4C23-B9E0-4679DFEF38DD_zps
And a last one with the cat.
E09FB5DA-B1B1-48DD-9FDD-A90C28D495F3_zps
After a horrific 10 hours, finally got a stage 2 subframe fitted. Had a few hours at it the other night, then Steven helped for the remaining 7 hours! I'm sure we had the subframe on and off more than 10 times, with bolts not lining up and bolts snapping it was a fair challenge. Also fitted 2 harder engine mounts in the passenger side.
C1EE1465-F1E9-4D16-B1AA-D3431661B2DE_zps
BC3B8395-AE0E-4968-8024-1404C8ACF610_zps
86B17AC4-F8CD-42C8-9855-1BBF36E6B49A_zps
Many hours of not taking photos later.
A823923B-4452-487D-8BBA-58FDCBADE5A9_zps
0C3338B5-E091-4F1A-A9DC-597879DA1128_zps
62DAD43D-1243-493D-B3CB-E5A37FA92F2F_zps
68ED9517-362F-4549-94B4-7B1071B3D440_zps
Hopefully only a service to do before the polo social and blyton park, then it's a lot more working on the mk2...
How come you snapped bolts while fitting?
It was me that snapped a bolt Jake, one of the ARB bolts. This frame was a nightmare to fit compared to mine...
Yeh only one, I just typed it out wrong.
Been for a drive and it is a big improvement, steering actually happens :)
That's this Polo done its final drive, it's getting split up to use parts for the mk2 and to save another polo.
430 miles down to the B&B
D4CE62C0-F4E5-46D5-9E45-C7092B8E9045_zps
An early start, first there!
CF27E80C-7F52-4C69-B71E-0575C3F173EA_zps
Lunch break
808248B1-BCEC-4EBD-835D-4E3C6AEE27D3_zps
And a big thank you to Nige for all the track photos
2261EF38-2E43-4D52-A309-08C4D9FECC4F_zps
C5153E05-03BF-4A16-8670-0F0D9AADE824_zps
DE765856-C359-4608-B597-1F6DE562A04C_zps
79B52618-BEBC-4097-82BC-6E4709B1FCE0_zps
0815AC69-206E-4ACD-8220-440A052F732B_zps
8C982AE2-5191-46DD-97E8-5A5AAA4A034A_zps
F2F72F40-BECE-4EBB-8DC0-4A26E375B6BA_zps
06CB1BD5-5342-48BE-8415-24016D8C9D50_zps
BD98B01D-51DF-4B98-B7EC-7B9B5DA8933C_zps
A0FAD882-8328-4021-AB93-AF9F1F0935D5_zps
Managed a total of 78miles on track, and used 18 litres of fuel, only put enough in for 20 minutes at a time so I didn't lose any on the left handers!
And a GoPro video of the first session, where it got a bit hot and the oil buzzer came on, hadn't lost any bit topped it as t was a few mm from the top of the dip stick.
No other mechanical issues, which is surprising!
Edited by citrus
