JL audio - subs and amps
here for sale is two JL audio subs and amps
the subs are two 12inch in a double box
spec:
•12" W3V2 Series Subwoofer
•RMS Power Handling: 300 Watts
•Dual 2 Ohms Configuration
•2-1/4", 4-Layer Voice Coil
•Kapton Voice Coil Former
•VRC Technology: Cools the Voice Coil
•Elevated Frame Technology: Enhanced Cooling
•Powder-Coated Silver Frame Finish
•Dished Cone/Dust-Cap Design
•Rubber Mounting Flange Gasket
Price
subs are £90
if people are intrested i can split and sell the subs each for £45
Subs can be sent out with courier for £8 each
the monoblock class d amp 1400d is - £sold
2 channel e2150 is - £sold
Collection from Runcorn
I can package stuff up and arrange a courier but charges will apply, pm me for details
Edited by pascoe92
  • Views 343
spec:
AMPLIFERS
Class D monoblock subwoofer amplifer 1400D
Spec:
•Class D Monoblock Full Range Amplifier
•High-Damping Class D Circuit with discrete contorl circuitry
•Pass-through RCA outputs
•On-board crossover: Variable Low-Pass Filter: 20 -200Hz, Selectable Slope
•High level inputs
•CEA-2006 Compliant
•RMS Power Rating (14.4V):
◦4 ohms: 320 watts x 1 chan.
◦2 ohms: 500 watts x 1 chan.
•RMS Power Rating (12.5V):
◦4 ohms: 200 watts x 1 chan.
◦2 ohms: 400 watts x 1 chan.
•Frequency Response: 10 - 250Hz
•Damping Factor: >500 @ 4 Ohms / 50Hz, <250 at 2 Ohms/50Hz
•Input Range: 200mV - 8V RMS
•Bass EQ: +6dB Fixed Frequency, Fixed 'Q' with port for optional remote bass control
•Dimensions: 11.81" L x 9.25" W x 2.36" H
Two Channel amplifer 2150
Spec:
•2-Channel Class AB Amplifier
•Absolute Symmetry Class AB Circuit
•Differential, Noise-Cancelling Input Topology
•RMS Power Rating:
◦14.4V
◦70 watts x 2 chan. @ 4 ohms
◦110 watts x 2 chan. @ 2 ohms
◦140 watts x 1 chan. @ 8 ohms (Bridged)
◦220 watts x 1 chan. @ 4 ohms (Bridged)
◦12.5V
◦45 watts x 2 chan. @ 4 ohms
◦75 watts x 2 chan. @ 2 ohms
◦90 watts x 1 chan. @ 8 ohms (Bridged)
◦150 watts x 1 chan. @ 4 ohms (Bridged)
•Low and High-Level Inputs
•Preamp outputs: 1 Pair
•Power and Protection LEDs
•Remote Bass Control Port
•Bass EQ: 6dB @ 48 Hz
•Adjustable Input Sensitivity
•Built-In Crossover: High/Low Pass 50 - 100 Hz
•Power connectors: 8 - 4 AWG
•Speaker Connection: 8 - 16 AWG
•Dimensions: 9.8" L x 9.25" W x 2.36" H
Price
subs are £60
if people are intrested i can split and sell the subs each for £30
the monoblock class d amp 1400d is - £30
2 channel e2150 is - £20
If you can pm me you are number might take the whole lot of you. Cheers
