01Mlacey's Mk2 Breadvan Project!
Hello all.
Where to start really,after a long period of unemployment sent me off road and forced sell the previous polos I'm now back on the polo scene. :)
In a stable job it was time to save a little and search for a solid polo,wanted another mk2 as the old tornado one came to an end because of a crash and i always loved it.
After months of searching and turning down shitters i came a across a 1985 polo c breadvan,62k,tax and tested and was the best id seen for a while so seemed a good base to start with.
So £450 later it was it was mine :)
Plans are to build a car that should last through m.o.ts hopefully for many years to come and also have something fun too drive
will more then likely go down the afh route on carbs rather than 8v this time.
So after lending a hand at a mates unit where he breaks cars for a living i managed to get free storage space so we got all cars stripped and stored and cleaned up ready for the projects to come in..
The breadvan in its new home for the next 6 months
along side jamies g40..
So the weekend after they were in the unit i made a start and got the polo up on stands and stripped down ready to be cleaned up ready for minor repairs and fully unsealed,All parts that are removed will be derusted and painted up so their good as new.
Its also very handy being where i am as lots of dubs are always coming so dibs on parts cheap is a plus! so i came across rear brake disc conversion bits..
So I've defiantly got alot to be getting on with.
Glad to be back on it :D
Edited by 01mlacey
  • Replies 20
  • Views 2.3k
Awesome start! Good luck!
Waheyy look who it is,
Looks a very nice little base, what sort of look is it going to follow then?
Having a unit such as that makes such a difference!
Should be an interesting read, good luck with your build!
well done fella good to see you back and good to hear your back in a job again
Cheers pal :)
Alright max long time no see,yes its great base 3 bits of welding to do which i consider minor and she,ll be 100% solid again.
as for looks will try keep it looking standard..ish which few bits and bobs
yes having the units bloody awesome just a shame i cant get up there more tbh.
Much appreciated pal :thumbsup:
good to be back mate :)
Edited by 01mlacey
You just gonna go for a bit of lowering and some fresh wheels then?
Theres a coupe equivalent to this rolling on pslots. Looks awesome!
bought a spare beam to refurbish before i got the polo so got that clear of rust and painted ad also had some angle iron welded in for streathening so much less twist in it now so very happy with the outcome.
Got some new genuine vw beam bushes many thanks to dale @ Genuine VAG Parts Supplier
Golf gti stub axles also free of rust and painted.
after removing the driverside win there was alot of surface rust so that was soon rid of
Theres a small hole at the bottom behind the wing at the bottom which should soon be repaired.
underseals in the process :)
thats me pritty much up to date cheers guys.
yes hopefully going for the Ap kit 60/50
Shweeeet ill check it out,on here i guess...?
Nice start chief. I undersealed my arches and wished I hadn't. Stupid stuff collects all the dirt!
Any engine plans?
Any engine plans?
yes it seems quite sticky although it been on there a few days,il be doing all underneath etc as well which should help pre-long the life of it hopefully it does,nt collect much once its had 6 months to dry :lol:
my minds just set on an afh on carbs atm no idea of what spec,main aims getting it back on wheels, then engine stuff will start to be brought.
Nice to see you back matey, works good so far, will be watching this.
Yeah it is mate. Aye, a modest drop and some decent wheels. Can't beat it!
I let mine dry for the best part of a year and it still picked up crap. But it will prolong the life of the car. I have donw arches and underside of mine too, but plan on stipping the arches off and stone chipping/painting instead
Made a good start, so look forward to seeing results.
Cheers buddy :)
60/50 should be sweet and better ide with ap kit hopefully,sick of ta kits.
thanks alot pal
Progress...
Headlight brackets cleaned and painted and yellow tint :)
Bought new tcas and phil j polys,inners are not split so gunna need a press or something
New tca bushes are but,going to paint them to match the rest then fit bushes..
Also got alot of the underneath cleaned up ready for underseal and spare wheel well is now removed :)
Thats about it for now :)
Edited by 01mlacey
dont need a press for the hourglass like inners man, just put the bush on the floor, rest the tca on it and stomp on it, went in first time for me :p
good times ill give it a go :)
Any updates lad?
This car is making me jelous, cant wait to start working on my coupe again!
  • 3 months later...
Any updates lad?
yes max theres updates just need time to sort pics out etc
the main stop in progress was waiting for the inner arch and sill to be repaired but that was done friday :)
cheers
Edited by 01mlacey
So... An Update:
So the main hold up was getting the rear inner arch to be repaired
did,nt look great at all..
All repaired and sold now :)
slapped n many layers of hammerite
lower bit of the sill had gone so got that done aswell
its gunna need a skim of filler no doubt and some stonechip paint to finish it off.
fitted the engine mount i cleaned up & painted.
refurbed bits & bobs.
380984_10151428770919086_1099091886_n_zp
Got some suspension..
549358_10151428523839086_105277058_n_zps
grill painted & pinstriped,yellow lights also on,this maybe off soon for derby front end ;)
164485_10152539854930062_981115850_n_zps
bulkheads now also gone still needs tidying up.
574627_10152539854795062_640864557_n_zps
46993_10152539854870062_1114889503_n_zps
And thats it for now folks,much more to come :)
Edited by 01mlacey
