mk4 grill removal
Read a few posts on here and it should be so easy but for some reason i can't seem to work this out, am i not looking in the right places for the clips?
Has anyone got any pictures to show me how to removal the front grill of a mk4 polo? Reason for removal is I'm planning on painting the badge.
Many thanks
  • Replies 8
  • Views 2.7k
To get the grille off you need to take off the indicators and remove th secrets under it, the poke a screw driver into each opening where the grille meets the front panel then pull.
If you just want the badge off then stick a finger into one of the opens and hold the grille with the other hand and pull it out.
Hth
You don't need to remove the indicators. Just release the 4 clips along the top, flat bladed screwdriver to do so and pull gently and the bottom will unclip
Hth
is it ok to take the badge off this? in the sense that it will be fine when i go to put it back in? Don't want to snap any of the grill taking it out so that when i put it back it won't stay in properly....
And thanks harris.racing; will try this tomorrow if we get a dry period!
bump
bump
harris is right , its just a few clips then its off , just be careful taking it off as i snapped a few of my clips :lol:
What's the confusion?
It should take literally no longer than a minute.
In fact my bro has a 6n, if I remember I'll even take a video
Am assuming my clips have got dirty and stiff, dont seem to wanna budge easily. Ill give it some greif later/tomorrow and see what the outcome is
its not gonna be easy to unclip otherwise itll come off whilst driving ;) just stick a screwdriver under the clip and pull iit out
