Picture of the rear light area of a Mk2
Basically, the rear end of my mk2 was crunched and badly repaired at some point in its life when it was much younger, since its been stood these bad repairs have rotted rather nicely.
The section around the base of the rear lights was particularly bad, being covered with patches there was no way of seeing the contours of the long gone original.
I cut this out and started remaking it, however i was thinking a picture of the area how it should be would be useful to work from.
This is as far as i got, i'm not to pleased with it to be honest but it was my first attempt:
Basically if anyone has a picture of that area but how it should be i'd be very appreciative if the could pop it up for me to use, its realy the areas that are hidden when the car is back together (by lights and tailgate) that i'm not too sure about. I've been keeping an eye out for a photo in the build threads section but haven't found anything.
I was hoping to find a repair panel/cut the section out of a breaker but nothings been local, and i just want to get the shell finished.
Thanks in advance!
Mat.
  • Views 807
^^ You're best ignoring the above links, they're coupes (the blue one is mine). Coupes are a different shape, and have different lights as a result.
Pics have some considerable limitations - I don't think you're going to beat simply looking at the other side. Unless you search the breaking section and can agree with the seller to go there and cut the panelwork you need from the donor car, and weld it into place on yours.
The problem is the other side is just as bad, therefore its not worth copying that, i have been keeping an eye out for one being broken locally, i know at this stage i'm never going to get the perfect oem profile by making it myself.
I did find a solid mk2 hatchback locally thats laid up in bits, the lad that owns it sold me a number of parts, the problem being its far away from the nearest power supply. I'd like to buy the whole car and break it myself but i just can't do that at the moment.
Thanks for the help though chaps :thumbsup:
Best I've got
