slow progress
a friend of mine asked me to put a 20v turbo in his mk2 golf gti 1.8 8V
i told him when he had all the parts to complete the build let me know and i'll make a start, well the car arrived 2 weeks ago wit a boot full of parts and boxes.
i started stripping it down last weekend
front end off
block out
1st clean
Edited by polo6n2g40
  • Replies 56
  • Views 8.1k
servo had to come off to access the loom
dash out in preperation for new pedal box
unfortunately he's sourced the wrong pedal box so needed some modification
removed the accelarator cable pull off the old pedal
and slid it onto the new pedal
the car was being converted to hydraulic clutch which means flatting a section of the bulkhead and drilling a hole to mount the m/c
new hole to reroute the loom
you dont hang around will keep a close eye on this one :thumbsup:
loom retaped and fitted
16v mk3 cable change box required minimal modification
i was ready to fit the engine but unfortunately my friend had overlooked engine mounts :lol: also forgot throttle cable, exhaust, bought the wrond DP from qpeng and several other parts so had to abandon it awaiting more parts
well he got a couple of vital parts over to me during the week so started again today
clutch line all fitted with slave and gear linkage with servo, trimmed M/C and mk3 fluid res with take off for clutch
new mount to use the mk4 5 speed box
100mm 16v mk3 driveshaft flanges
engine perched
2nd clean
loom split into lighting loom and engine loom and taped
that is all for now, got bored of the rain and cold. few more bits i can get on with but i am quickly running out of parts, hope he come through with some more soon....
only half a days work today, off to look at a new car for the mrs
started to mount the header tank
modified the bracket to fit the car and the mk4 header tank
welded nots on so i can use allen bolts
welded the bracket to the car
test fit
bit of paint
fitted
bonnet clearance
also trimmed fuel lines to length and connected them
and there was a lot of shortening / resoldering of the loom needed
have to say the massive bundle of earth wires was not me i reworked it with three smaller wires i worked into the stand alone loom and routed so can be eathed on the main chassis earth.
hoping to get the fmic mounted on the front panel so i can order some boost hoses and hard pipes so i can mock up a nice tidy boos pipe run from turbo to fmic and will also be making a new Turbo intake pipe.
Fair play man! U charging him much for the work?
Looks good as always Olly :)
Edited by Cooki3
today i needed to get the fmic fitted to the front panel, i was hoping to get some boost pipes ordered today for tomorrow but my mate has been uncontactable :x
he's gone for a sprinted fmic, not my first choice but hey ho
i made up a couple of brackets to fix the fmic to the slam
got it sitting where i wanted and welded them in place and welded nuts to the back
once that was sitting right i trial fitted
i wanted to make a bracket to make the intercooler more secure so found a bracket in my scrap bin, cut it to size and welded a nut to the back
worked out where it needed to be
and welded it in place
threw a bit of paint on
and trial fitted
next was the rad, the one he provided was no use so decided to use the mk2 gti item. with the fmic it could no longer sit in place, so found a motorbike headlight bracket in the scrap bin and lopped a bit off and cut to size
worked out where it needed to go
and welded it on
threw a bit of hammerite on
and sat the rad in place
before i fixed it in place i thought i'd fit the fan and battery to make sure nothing was in the way
with the battery in it seems the boost pipe path was going to be tight so layed the rad forward slightly
and modified the bracket
a little more room but not ideal
all in
also managed to do a couple more bits, trial fitted the washer tank and mounted the catch can
and fit the modified 3" cable driven TB
and finally tried the grill back on before i packed up
tomorrow will probably be wasted now, if the boost pipes had been ordered today as hoped they would have been here in the morning but i guess i'll be waiting around now for more parts :-(
looking good :D wish i had the motivation to do stuff in the rain lol and i own a garage :o
Fair play bud! and ashi same! seems he always works in the rain.. well the couple of times I've been he was always outside on the bora
managed to get the hoses and pipes ordered today so hopefully they'll arrive tomorrow.
i just spent the morning tidying the loom, made a new section for brake res fluid sensor
tidied and shortened some of the scuttle loom
tidied up the looms on the passenger chassis leg and crimped on new earth terminals etc
fitted oil sensors and connected loom
refitted scuttle panel
and started to make a bracket for the throttle cable
BOOST HOSES ARRIVED :thumbsup:
i jumped straight to it and chopped all the hoses down and made a Turbo intake pipe before i realised i wasn't taking any pics
next was to tackle the rad hoses
new silicon bends
trimmed and tried
trimmed again
fitted
top hose was a bit easier and joined with 32mm OD 2mm wall alloy tube
next was the throttle body to intercooler pipe, trimmed the first bend to get it where i wanted
then the reducer
trimmed and fitted
once that was done i started to look at the fmic outlet
also ordered some 8mm blanks
and fitted one to the outlet on the rad
the mk3 front engine mount arrived so i droped the front back off, fitted the mount which also meant i could fit the starter motor and finish the loom in that section
and also fitted the forge sai blanking plate
quick pic as it was getting dark
will get some new cutting discs and mock up the turbo to fmic boost pipe then take it with the inlet to the ally welder
top work as usual mate!
Well impressed with this.
thanks for the comments so far chaps :-D
got up this morning, was supposed to be fitting coils to my mates A4 and mocking up the boost pipe for the golf. mate turned up so told him he could take me to get som cutting discs. on the way some clever person in a mondeo cut off two cars and caused a nice little smash and wrecking the front of my mates car. :x
after a couple of hours faffing round and waiting for recovery i got back to mine and went to get some cutting discs, got back to mine and started mocking u the pipe.
beads trimmed
bends trimmed
trial fitted
bends trimmed again and straight section fitted
and all stripped out and taken to be ally welded
i will trim another 10mm out of the Turbo Intake Pipe to give a little extra clearance when i get the pipes back
now i had the new hubs, i could fit the brakes and driveshafts
gti 8v vw2's
16v mk2 hubs, 280mm 2 piece discs, S2 calipers and braided lines
re mounted the second horn from the grill with the other one in the inner arch
and refitted the front bumper
i sorted 95% of the loom, it turns over and we have spark and fuel injectors are firing but no inlet mani so not able to start.
waiting on a few more parts and the bits back from the ally welder and should nearly be there :-D
Then the disgusting grey bumpers need to be resprayed!
:lol: new bumper i think bud
not a lot i can do now while waiting for parts and the bits back from the ally welder
i trimmed 10mm out of the tip and repositioned the alarm siren
and made a bracket to hold the filter in place
modified and fitted mk4 starter loom channel
also decided i'd trim 20mm out of the power steering res bracket
then i remembered i had to run the loom for the sub / amp and HID relay, i decided 4 wires on to the + terminal was too much so went to my spares cupboard and got a mk4 battery fuse box
i decided to make a cover to hide the last bits of HID loom next to the battery
i also fitted new fan switch, trimmed a couple of lugs off the rad and moved it in the last couple of mm to give more room for the boost pipe
