slow progress
one word ollie legend
  • Replies 56
  • Views 8.1k
Great work as always Ollie. You probably have to give you some money soon when it comes to wiring my polo together...it'll all plug in but i bet it wont work :lol: ill chuck you some cash to come stay in a hotel and do it for me ;)
well the ally welder rang me today, parts were done :nod:
also the start of the final list of parts started trickling through - manual boost controller as this management has no N75 valve
barbed outlet for uprated pump
but for the main event; T-piece
inlet mani lug for cable
turbo to FMIC boost pipe
8mm take off for actuator
fitted up the inlet
trialed the boost pipe
T piece for coldside DV
oh started it up too.
thanks for the comments chaps :-D
Ahh Olly I'm so jealous of your car knowledge
Jakey boys in love <3
a friend of mine asked me to put a 20v turbo in his mk2 golf gti 1.8 8V
Wish I had a friend like you :lol:
Nice work dude.
haha thanks chaps :thumbsup:
looking forward to getting the last bits and the final fit and clean :unibrow:
You'll have to record a video of it driving for us to watch :)
hopefully most of the remaining parts will arrive today so can get it finished this weekend bar the down pipe that is on back order from Qpeng
more updates will follow this weekend :-D
had more part to use that had come during the week
first up was the shifter tower 02j - 2001
'new' mk3 16v
new plastic linkage bracket
fitted
then was the water housing, the old one had died and the centre that locates the o ring crumbled away
a little more trimming on the fmic elbow for more clearance
fitted, just clears
the oil catch can mounting needed better fixing
i enlarged the hole to 9mm
and got my m6 rivnut
fitted
i fitted a second one and made a new bracket
mocked up the new run for the breather pipes but need to order some clips
also made brake servo vac
packed away for the day
<3
not a very productive weekend, rain cold and missing parts :-(
well DP arrived friday trial fitted bt no gasket :lol: so i text fitted bt there was a problem
obviously i'd rather the car had a full system to compliment the engine upgrade but it's not mine so i have to do the best with what i've got so assembled what bits i cold lay my hands on at short notice
when the DP comes back off to fit the gasket i'll put some slits in it and clamp up the centre section
other than that i've been making up loom sections to sort the little bits, temp sensor, rev counter, lambda loom and heated element, speed sensor loom and wired in the mk3 gti clocks. also started to tidy the dash loom but pics of soldering and wires are hardly worth taking pics of :-D
been a while, been waiting on parts and weekends :lol:
got the gear linkage specific bolt / washer and nut
loom plugs for mk4 header tank level sensor / speed sensor and starter wire
and 'repair' wires
despite the weather decided i'd set about fitting the mk3 16v clocks to the mk2 dash
decided roughly where it needed to go, unfortunately the mk2 brackets were no good so made some new ones up from stainless
final 'cut'
the problem with the mk2 shroud is it covers parts of the mk3 warning lights and fuel and temp gauges
i cut grooves in the back
heated the plastic and flared the edges and pulled the bottom down
dash back in
as it's christmas i thought i'd do some work
removed the last of the grime and waxoil off the drivers chassis leg and gave the bay a once over
then turned my attention to the 'new' centre console
i had the cut the window switch plate out and fix it into the new section
trim the front off the original console
drilled hole for cig lighter loom
wired in the new boost / volt / oil gauges
and made looms so an be unplugged individually
bolted the ecu to the tray under the glovebox so the serial port is accessable when it goes in for mapping
fitted the center console and wired in
Brilliant, TOP work there mate, can't wait to see it finished
todays task was to tackle the alarm 'wiring' if it had been my car i would have ripped it out and started a fresh with a new system, this job was not on the to-do list from my friend but i honestly couldn't force that jungle of wires back up abouve the dash tray and been happy about it
loads of lovey cheap black tape
and most wires had to or 3 joins and near enough all joins looked like this - all with black tape
chopped out the joins and resoldered all and insulated with proper heat shrink tube
then bound the looms in fabric tape
again de taped
chopped wired to length, soldered, shrink tubed and taped. all bound ready to be fixed up out of the way
secured
removed all this
just need access to 1 or 2 more wires then the tray can be refitted and screw the alarm port and program button in place
thanks vr6man, shouldn't be too long, to do list is very short now :)
Awesome work dude, you really have a nack for doing this sort of thing,
Loved your old arosa!
Fantastic work and an interesting read! I like the fact you do things properly where most people cut corners! Keep up the good work :)
X2, my thoughts exactly
thanks chaps, much appreciated :thumbsup:
well not many pics today, absolutely peed down all day. spent most of the day doing the niggly bits;
checked all nuts / bolts etc were tight
pressure bled brakes and clutch
drained and refreshed P/S fluid
put the dash under tray back together and column shroud
sorted out the brake light switch
dropped the down pipe back off to put some slits in it to clamp it to the centre section and fit new turbo - DP gasket
now the drivers side dash undertray was back on i could attatch the alarm port and MBC
it moved off the drive today under it's own power too, took it down the road - the tracking is a mile out and the splash guard was touching the disc, other than that the speedo wasn't working, double checked the wiring and checked the voltage on pin 1 + 3 and was getting 12v so is either speed sensor on the box or the clocks :(
couple of finishing bits left to do and fit some new arb links and should be all done :)
as there's very little to do now i thought i'd tidy it up ready for the final parts
emptied all the old parts from the interior and gave it a good hoovering
then treated all the plastics
next was to give it a good jetwash in all the seals / shuts and wash n wax with meguirs
then treated all the plastics and rubbers
before
after
