Breaking 1990 GT Hatchback/Breadvan
This will be broken over the Christmas period all being well.
I may be able to remove/post smaller parts in the meantime when I go back to Oxford at weekends etc. I can also bring items back to Bristol too, upon prior arrangement.
All parts located in Oxford. I am breaking a White 1990 GT Breadvan. The shell is tired, circa 136k.
I bought the car in January 2008 and used it daily until I had a blowout in October 2009. It then came off the road and resided on my Parents' driveway ever since!
I'm not interested in removing time consuming items myself unfortunately however i'm more than happy for you to come and remove them yourself if you would like.
I'm not near the car now however here are a few prices.
GT Head including cam - £90. No smoking from the valve stem seals and from what I can recall, no scores on the cam - it's in VGC.
I would be more than willing to split the Cam & Head - £45 for each item respectively.
GT Distributor - £30
ECU - £25
Throttle body - £30
GT Inlet Manifold £40
Injector rail & injectors £25
GT clocks showing circa 136k - £25
GT Engine Bay wiring loom - £30
GT Bottom end - £30 take the gearbox & driveshafts as well. It's floppy in neutral however the gears change very smoothly. (You'd have to remove this yourself)
I will be adding more items when I next go back to Oxford, remember this is a whole car so I have panels too! It's alpine white.
Take the whole car for £200 if you like. The V5 is present, as is a few years service history. it's in my Fathers' name.
Please PM me for more details. I'd like to take deposits for the items if possible, that way I know you're serious in buying!
Martin
  • Replies 29
  • Views 1.9k
Have you still got the breadvan ? Could you send me some pictures ? Would be very interested on buying the whole car cheers tom
Any chance you've got working mass airflow meter from it for sale??
Hi there after bonnet catch and bolts that hold it In
how about a rear brake pressure reglator of the rear beam posted
ill take the spring for it aswell
Scuttle tray? is it in good condition... no cracks or breaks? let me know. Thanks
what colour are the carpets?
I'll have the driver's side wing please.
Update:
The engine (minus bottom end) are all sold i'm afraid.
Will have to get back to you lot in due course as i'm nowhere near the car currently.
Martin
Do u still have the engine loom bud?
Hello mate bit of an odd request but I'm after the piece of material that goes down the drives door of the window to prevent the window ratteling and letting in air etc...
I'm not entirely sure what they are called but if you need me to photograph it i will
Kind regards
Kieran
Interested in the head and cam if you could post them?
you still got the gt fuel pump
Update:
Martin
Hi mate- do you still have the gutter trims for this available and if so how much?
Cheers- Mark.
beam posted to devon or may be amle to celect from bristol
Pretty sure I PM'd you about something but I don't remember what and I don't have the PMs any more so anything from here?
You selling the fuse box? And how much if you are?
@manny, afraid not. Goes with the loom & engine.
@G40dabbsy haven't ventured that far yet mate. Will bve in touch in due course but the rear beam and associated fittings may have gone.
Cheers- Mark.
Nope. Had to rob one as my current mk3 items were damaged after a trip to the safari park at Longleat by some monkeys :lol:
Hiya, do you have the parcel shelf supports? (assuming it's a facelift) and could you post? :D
gt rear beam?
How much for steering column, ignition cowlings and stalks?? Needed ASAP tho!!!
Driver's door seal any good ? if so how much posted please ?
Received my pm?
