AFH timed wrong? also head stripdown.
Hey guys.. Just checked my timing and found this...
surely the marks are supposed to be on the 2 teeth closest to eachother?!?! Looks like both cams are a tooth out???
Edited by erixtar1992
  • Replies 115
  • Views 7.7k
according to autodata they should be. ill upload the picture now.
So they both need to go up a tooth? would that explain my poor starting and possibly smoke?
Looks out to me, should be level with the top of the head with the bottom pulley lined with the TDC mark
Edited by Mclovin
Fuck me! What a cock!!
Guy what mark? I cant find a lower mark
Fingers crossed this is the cause, it certainly won't be doing it any favours that's for sure
Have you ever timed up an afh? If not probably best to get your swear tin out cause it can be a right fiddley pain in the arse :-(
I'll get a pic in a second, just gotta drag my lazy arse out of bed :lol:
I haven't mate. Gonna give it a go now tho!
Thanks dude. Appreciate it
Shows the lower mark too.
Inlet at 3, Exhaust at 9, Crank at 12
Remove the alloy cam cover bit and look down at the bottom pulley, when its at TDC a tooth with the corners missing will line up with a mark which I believe is above the pulley (can't get a pic of that cause engine isn't here) but iirc its a little triangle shaped thing on the crank seal casing
It's the tooth with the tipex on it
Just line the top pulleys up as best you can and it should be daily obvious what you have to line the bottom pulley up with as it will be pretty close to it
100% your cams are a tooth too low
Also when you tension the belt the bottom pulley moves slightly so accommodate for that too
Edited by MoustacheG40
Just realised I still have my crank case knocking about
Think its the small knotch above where the pulley would sits (maybe someone could confirm? The big one has 2v and the small one has 4v stamped next to it)
Cymro I've looked on my afh pulley and there are no timing marks as shown in your illustration, although strangley there is on my 6n2 aux pulley
Edited by Mclovin
There should be a little slit in the aux pulley, I wouldn't use it anyway, even though they have a locating peg mines well off true TDC. Use the one on crank toothed pulley.
It's the dead vertical lump on the seal housing casting I believe, if you're unsure, take your plugs out, drop along extension into cyl #1 (closest to belt end) and turn up to TDC, it will be higher either at the 2v mark or 4v, tbh I think it's the vertical one, but no harm checking.
Eric its got to be spot on man, ensure it is, and remember to turn it over TWICE by hand before even attempting to start :)
It's the mark stamped 4v next to it on guys picture. As nick says the most vertical one. And yeh forget the aux pulley
He has a moustache and agrees. Must be right!
How do i do the tensioner? I keep turning it too far and loosening it
If you're loosening it then you're going the wrong way Eric. Tbh its a right pain in the arse to keep the pulleys in position while tensioning it. If you can find a way to lock the cams in position you will make your life a hell of a lot easier
You cant go too far with the tensioner, it can only get tighter if its going the right way, the arrow just be pointing to around 2 oclock, somewhere in that region, maybe abit more. it should tension in a clockwise direction
My moustache is fat atm, movember and all, think I'm gonna keep it for the shows next year
Thats more like it eh!!
:thumbsup:
Well, it turns over! No wierd noises!!
I have however managed to kill a day old battery from trying to start it earlier fml!
