Wet Floor: Rear Passenger Side
Hi,
I have a 3-door 6n2 GTI and my floor carpet behind the passenger is soaking wet.
I cleaned the drains under the windscreen (by the wipers) and it didn't help.
Am I missing a rear drain somewhere?
Also I'm missing the rubber around the antenna, could that be it?
PS
The door and wall seem to be dry so it doesn't appear to be from the door.
  • Views 1.4k
Might be talking rubbish here because I don't know 6N2s but I think some Polos have problems with leaking around the rear light assemblies.
Is the rear washer working OK? as there is a production break in the pipe by the rear passengers upper seatbelt mounting point, mine popped apart and flooded the boot and footwell
