engine for a 6n2
well time has come engine is on its way out its a 1.4mpi thats been to the moon an back and i want something a bit faster for its whats the best engine to fit into these thanks
  • Views 646
GTI if you want cheap and easy. 20vT if you want it to be fast and expensive.
Was thinking more along the lines of the 20vt you got any idea what there like to do
No specifically. But I can imagine you'd need to look at what gearbox and linkage your going to use, what engine mounts you would need, how you are going to wire it in, what drive shafts you will need. Will need to upgrade the brakes and probably go for a custom exhaust. Cost will all depend on how much you can do yourself.
Yeah I can do it all myself just would like to hear from someone that has done it before so I know what I'm letting myself in for !
few threads in the MK4 section mate, mine being one of them
loads of things to consider
drive shafts, brakes, mounts, wiring, exhaust, gearbox choice, intercooler fitment
id definitely do mine again as the car's so much fun... there's loads id do differently though
Did you use a donner car or did you buy it in bits what's shafts breaks did you use ?
