NEED HELP!
Hi all, looking for a bit of help with my 6N 1.4 16v
I have a problem with my wiring behind my head unit. was driving down the road one day and smoke began to billow out fro behind the dash!!
After everything had cooled slightly, i took the head unit out and discovered wires had melted and stuff (all a bit nasty looking) The loom than connects the car to the head unit is fine, its the loom connected to the car that's knackered. Was looking to see if anyone had any idea what this loom is called (if it has a name) or where it leads to because when i try to follow it with my hand it joins into another loom and heads up over the clock (speedo etc.) Not a clue where it goes to after that.
Any advise would be great on this because living without a radio or even the same C.D. over and over again is driving me mad!!
Please help! :-(
Thanks, Scott.
  • Views 412
First Welcome to the forum.
Have a look at this http://www.clubpolo.co.uk/forum/index.php?...p;#entry2039719 I've posted the wiring diagram for the standard basic VW instalation, you'll need to follow the wires back untill you get to undamaged section, then splice the replacement wires onto the undamaged ones
