Polo 1.2 - First Car, how do I look after it?
Hi, I am 17 and have a 10 year old Polo as my first car.
I have only been driving a couple of months so would like some advice on how to look after it.
I added coolant for the first time this week as the temperature light was coming on. I will check this regularly now. I also did screen wash and checked the oil (5/30 apparently) but the level was fine so will buy some and keep checking.
What else would people suggest I do to keep it running well?
  • Replies 20
  • Views 1.6k
tyre condition and pressure, check the thread depth andpressure regularly every week for a few weeks then if all is well, every fortnight,
oil change service, is a nice one to be able to do at home, ECP have forum discount.
preventative maintenance is always the best way to go about things
do you have service history for the car?
Any MOT reports? Advisories?
What kind of mileage has it covered?
Is the timing belt due for a change? has the brake fluid been changed in the last 10 years?
How much do you want to do yourself? and how much do you want to get done at a garage?
Any car maintenance night courses running in a local college near you?
Does your family have a background in cars?
When was the oil last changed? You want to change the oil, and oil filter, every 6000 miles really. I do 4000.
Air filter too, as it'll keep your economy tip top.
And the same for tyre pressures - very important to keep them right, 26-32psi depending on preference, i do 29 rear and 31 front of the light Polo and 28 rear 33 front of the heavy Golf, just because i like the way they run on that. Not anally important though, just ensure they're around 28-30 you'll be fine.
Brakes you just check your fluid level, have some meat on your pads, discs look more like a CD than a vinyl record and they work. If they feel squashy then get the fluid changed (not an easy job for the novice to get right).
Keep it clean! Detailing is all very well but get the jetwash under there and get the winter salt/grit and any mud out of the arches etc.
Maintenance - if something is broken, it can cause further issues. Plus if you don't keep it nice you just won't care to anymore. All too often i see cars where the money has been put into an expensive stereo or wheels, and not into maintaining it. Before you know it, it's a shed and the wheels/stereo get sold and it gets scrapped. Keep it tidy.
Don't go mad. Spend all your cash on your car and you'll end up miserable - there's more to life. It doesn't need much to keep it maintained, steer away from all the marketing hype and just keep it in good order, it'll be fine.
haynes manuals aren't all that they used to be, just keep that in mind, especially not for a 2002 car.
make good friends with a decent aprentice mechanic who is local, excellent way to learn and great source of info for questions
Edited by mini_mayhem
Thanks for the responses. I guess to answer one of the questions I want to know about preventative maintenance. Bigger jobs at the garage.
Service history is there, 89,000, passed MOT ok but ABS light keeps coming on and has been back to garage twice and is back on again??
I hadn't thought about air filters, I'll look to see where that is!
I tried to check the brake fluid but it was too dark too see the level, will look again tomorrow.
Car maintenance course is a good idea, i'll look into it. and good advice about keeping it clean! I'm fairly frugal so i'll make do with the stereo but i dont' have lots of money to fix things so I want to do all the little jobs i can.
thanks for the advice every one.
thats over kill, there's no benefit (and wasteful) changing the oil that often unless its tuned or the car is being used in harsh conditions.
on the 6n i change the oil every 10000 miles and not had any problems in the 70000 miles i've done in it since i bought it
in 08, the peugeot has similar service intervals and and that is getting on for 110000 miles without any engine issues.
my dad's vivaro has service intervals of every 18000 miles or once a year!
oils are a lot better than they used to be and stay in grade a lot longer so changing the oil every 6000 miles is unnecessary.
i suggest following the recommended service intervals and change the oil and filters at least once a year
Just because you haven't had any problems doesn't mean that running 10k old oil Isn't allowing premature wear. The condition of oil at 8k is inferior to that at 6k typically, though it does depend greatly on how the vehicle is used.
Fleets want high mileage so are told they can do big mileage but it's not ideal. I know someone who lost an inlet cam at 13k because his old company car did more, but his own car did far shorter journeys. Oil changes aren't expensive or time consuming, (it takes me literally five minutes), nothing is more important than having good oil in the engine so what's the good in stretching it out into borrowed time..?
I'm with mikey, short oil change interval will prolong engine life. with my AAV i did it every 5,000 miles, or 3 months. the engine was a blast and never let me down.
the AFh has had it first two in under 1,000 miles to flush it through, and I'll stick to my 5,000 interval, as i can do it for less than £20, including filters, quality oils and sump stud washers.
if the budget is tight then, you nreally have to keep on top of everything.
I'm no help for the abs problem.
if you can keep on top regular checks then you should be able deal with issues before they become too major.
at nearly 9ok miles,the timing belt should have been done at least once already, if it hasn't get it done and the water pump along with it.
Thanks again everyone. looking through the paperwork it looks like the timing belt has been done once. Is the water pump something the garage would do?
Oil change, do you literally mean taking out the old oil rather than just topping it up?
if the timing belt has been done, can you find the paperwork, the water should have been done at the same time.
the water is possible with some tools, but dont worry if it was done with timing belt. make sure it gets done with the next timing belt service too.
Yes, oil change is draining out old oil and refilling with fresh/clean oil.
you will find your sump on the bottom of your engine, has a sump stud 19mm, this holds the oil in your engine, if you remoe it the oil will drain out.
then undo the old oil filter, and replace with a new one, HAND TIGHT, and a smear of oil around the seal to ensure a good fit,
then back in with sump stud and new copper washer on it.
fill with new oil. if you pull up the dipstick slighty top help the air escape as the oil is poured in, you wont make as much of a mess.
http://www.pistonheads.com/gassing/topic.a...elt+-+why%3F%3F
so glad my timing belt and water etc was all done when i purchased my new car - nothing to worry about for a few miles now! £950 quid for a VW service is ridiculous in my opinion, but then hey ho, i didnt pay for it, previous owner did :lol:
great, thanks for explaining. i will give that a go.
New oil apparently lubricates worse than used oil. It can take up to 3000 miles to 'condition' the oil. This condition can last up to 12-15k. It's a misnomer to recommend oil changes regularly. Filters on the other hand should be changed more regularly
Don't Put it into a tree, that should look after It alright
Is it a 9n polo by any chance? If so you might want to check the fuse box above the battery as this contains the abs fuse, I've had the same problem on my car an doing that sorted it.
If this is the 1.2 don't they run on a chain rather than a belt in which case surely it wont have been changed. Although its worth checking that the chain tensioner has been updated to the revised part as they are prone to failure in the 1.2.
Best advice i've been given for the parents 1.2 9n is never to rev it just after its started. The timing chain can jump a tooth as the tensioner is oil pressure driven.
hi, I'm not sure what a 9n is, how would i find out?
It's the code of your age of Polo....
That's a 9n :)
the 6v's run on a belt and 12v's on a chain iirc...
