Everything I've got G-wise- shell gone so all must go!
The Engine
PY Block, bored to 77mm.
Fitted with 1W crank (new)
PY Rods
Accralite forged pistons and matching rings.
New bearings, (some VAG some not (obsolete)
PY Head (stock)
VAG Metal HG
VAG Head bolts
New VAG Oil Pump & chain.
Sump.
6N Cam Cover.
GT Inlet manifold.
G40 Injectors and fuel rail.
Water pump (new VAG)
New crank pulley and bolt.  ;)
No TB
Comes with sump gasket (can fit with sump if required).
Comes with timing belt (new VAG) and covers.
Comes WITHOUT cam and vernier
Crank, pistons, rods and bolts were all balanced by Graham Goode Racing.
This engine was built by me, I checked all the tolerances as per Haynes and everything was spot on (hardly surprising with everything brand new). This is not a guarantee however, I'm not a pro and I bought the bottom end built and rebuilt it to check for myself, which is probably what I'd recommend any buyer did. There are two methods of getting the 1W crank in a PY block, you either shave the rod bolt head on one edge or you machine away some of the material from the block where the oilways run across the casting. I went for the shaved bolts as you can always change your mind and go the other way. Plus there's no change to the integrity of the block. Both ways have pros and cons.
Pics here, but bear in mind the exhaust manifold, turbo, cam, vernier and thottle body are not part of the deal...
Price for this £1100.
Other bits:
PACET fan, with unused thermostatic controls, (I spliced into stock thermoswitch on rad). Works fine and cools very effectively with the added bonus of not taking up loads of room. You will need to buy some more of the cable ties to fit to rad as the ones supplied are one use only. £60 + P&P.
AA58B869-F514-499D-B6BE-6B9C24656757-521
A692347D-5C47-4118-B051-BDED86801BFB-521
STACK Wideband AFR - Used but in very good condition, winter plug on looms still fine and comes with lambda probe (also used). Option for what switch to give recall facility on gauge. £190 +p&p
Bosch 044 fuel pump. Done less than 5k miles. Not used by me. £50 + p&p
OMP Targa Suede Steering wheel with boss to suit Mk3 Polo. Used but in v.good condition. £130 +p&p.
8D3F3829-955E-486E-8EAA-265DA243101B-521
Alloy Intercooler, new in box. Measurements as pictured. £50 +p&p.
Edited by Alexg40
  • Replies 17
  • Views 884
Any pics of the carbon door cards mate?
How much for the Stage 3 sub frame
At the minute thats the only pic of the doorcards I have. But they're not for sale yet anyway unless you buy the shell with them in!
Likewise the subframe isnt for sale till there's a deal done on the shell. But price would be £400.
Shame your breaking looks like a great setup!
Got a price for front coilies? How low they go?
They go so low you can't drive it. But they're not for sale yet.
i cant qfford them right this minute eanyways, just wondered if you had a price in mind for when you do :)
I've just written my Pearl Grey off, Can you sort a deal out with me for the shell?
Other bits now up for grabs... see top post for additions!
Clutch driveshaft and oil cooler sold.
What size is the pacet fan? cheers
11" matey.
Taken a deposit on the engine today. Still bits left though...
Would you take £50 posted for the inter-cooler??
£60 posted for the oil separator??
Pmd
Edited by Alexg40
Gearbox, Oil Separator and Intercooler sold. (Pending payment and postage)...
Radiator gone.
