Mk3 Water Leak
I have a Mk2f polo which is leaking badly. Every time I get in my Polo there are puddles in the front foot wells, am taking about an inch of water here.
So far I have checked and replaced the door seals, bin bagged and duct taped the door linings, checked the battery tray for rust. Unfortunately the water just keeps coming.
I have heard somewhere that the sunroof has drains which run down the A pillar and these can become blocked. However I have searched the forum and can't find any information about these drains or how to clear them.
I might be barking up the wrong tree with the drains, any help is appreciated.
Edit: forgot to mention the sunroof is a pop up one, not sure if this is a factory or after market one.
Daniel
Edited by Torrevez
  • Replies 12
  • Views 1.9k
Sisters Mk2 (non-sunroof) has the same issue. I've fiberglassed and resin painted the whole battery across to the fusebox and it still happens. :(
These drains you speak of should be in the corners of the sunroof and just require a poke with a length of wire to clean out.
After doing some more googleing am not sure the sunroof is a factory fit. If it's not am guessing it doesn't have the drain holes.
Edited by Torrevez
might need removing and resealing. Got pics of your sunroof.
I dont at the moment, but it isn't one that slides back. It pops up out of the roof.
Since you've got the carpets out, just sit inside it in heavy rain or get a mate to spray it with a hose, then just look for where the waters trickling in.
Its a long shot, but if the drainage pipe that pokes out the bottom of the scuttle tray in the engine bay is blocked, water can back up, fill the scuttle and then leak into the car. I've only known it happen with prolonged heavy rain, but its an area to look at anyway thats cheap to fix.
Dust all the way around that puddle with talcum powder or flour. When it leaks you'll see a trail where it ran down into the puddle. This will put you on track - then dust further in that direction and you'll narrow down the trail. Then you have somewhere to investigate.
This may be a silly suggestion but check behind the dash for holes in the battery tray. You can't always see it from the bay side.
I have done a little more investigation at the weekend and it seems that the little triangles of carpet on each side of the foot wells are wet so it would suggest it is coming in there some how. Can't figure out how though, is this a common problem?
windscreen been replaced? there are drain holes under there
As mentioned sit inside with the seat out and somebody to unleash the hose!
The battery tray can leak even if it's not rusty, has it ever been repaired?
that floor pan dont look to good to me or is it my eyes also have you checked you sunroof seal any water staining around the headlining ?? or like said before me sit in the car and get someone to put a hose on it
