Rear washer pipework
Hi
Could someone tell me where the rear washer pipework runs on a 9n3 facelift polo. The motor is running but isnt getting to rear wash I have prodded the hole with a pin but nothing!!!
Cheers fella's
  • Views 873
It has probably become disconnected it's a common issue on the fabia perhaps a look on their forum would give you an idea about where it becomes detached. Also it could be frozen? My washerbottle was frozen solid yesterday.
On the 6n there is a production break by the passenger side rear seatbelt upper mounting point, mine had popped apart and was filling the boot and the rear passenger footwell.
Cheers guys will investigate it
Thanks again guys tried the rear door was still attached then noticed a puddle of soapy water around front passenger wheel found it was the connection just by the battery put back together and hey ho one working rear wipe!!!
The Power Of Forums!! :D
