Removing Wing - MK3
As per above,
I can see the bolts in the engine bay, where are the other bolts located?
Thanks!
  • Views 1.2k
Behind the bumper, at the bottom of the wing behind the wheel. Then take the arch liner out and there's 3 10mm's that go through the wing into the A-pillar. These will be coverred in underseal and an arse to find.
Once you've undone the bolts along the top of the wing, theres one solitary philips head screw that joins the front edge of the wing (near the indicator) to the grille rail.
Then look near the sill. Covered in underseal will be another 10mm bolt the same as those found along the top of the wing.
Finally, with the arch-liner removed, look along the back of the wing where it meets the a-pillar. Covered in waxoil and underseal are a further 3 10mm bolts. Undo these, and then thats all the bolts holding it on removed.
Next job is wrestling it loose from sealant and cavity wax. It's not impossible to do, but it takes time and patience so you don't distort the panel.
Should be a sticky as i've seen this asked before, Martin do a how to with photos for fun :)
Depends on how cold it is Jake!
put a jumper on you'll be sound :)
