such a shame
  • Replies 17
  • Views 1.3k
But what damage has the water done? Did the owner drive it into a lake during the floods? Dead engine?
i would be willing to take the risk tbh, have a little fiddle and get it running again :)
Copart is the bomb! My dad fixes up salvage cars so he uses this and HBC frequently.
Has anyone encountered those car part websites where you have to enter an exact year, make, model, trim, engine size, fuel and exactly what part you want? Those are so stupid.
If i were to sign up to this, do i need to own a company or something like a breakers yard with liscenses etc...
Just a Audi TT on there that tickles my fancy...
Nope, you just need £50 sign up fee and an old electrical bill and go into your local yard and sign up then start bidding away.
You only need a yard licence etc if you were buying a cat B breakers yard!
Collie
Whenever we get a water/flood damaged car in at work, it's written off instantly. The risk of the water it's been flooded with containing sewage is too great to warrant putting it back on the road.
If people caught any illness through for instance the heaters blowing out air full of hazardous bacteria, we'd be responsible!
It's not that it couldn't go back on the road again, but I'd be gutting the inside and thoroughly cleaning everything, if not replacing everything.
worth it for the engine though, then break it down for parts and scrap
If you could get it for sub £500 it would probably be worth it because if worse comes to worse and the engine has hydro locked or some thing and is fucked, you could still make your money back breaking it and probably a bit on top to make it worth the effort. Any more than that and your only best hope of making it worth your while is the gamble that the engine isn't fucked and you can get it back on the road cheap enough to still be able to make your money back on a cat C car. If that gamble doesn't pay off you could be in a situation where you would of been better off buying a decent one at market value
Only if the engine isn't scrap, could of been driven through a large puddle/ford and hydro locked which could mean bent valves and rods as well as other expensive shizzle
possibly (price depending) worth the risk as even if the engine is scrap the kind of price its at now, breaking it will make that kind of money back, GTI seats, dash, wheels, splitter, grill, 6n2 lights, GTI xenons,... all worth a bit, and if gearbox is good they go for big money compared to a generic 085
Oh fo sho, I said the same kinda thing in the post above that :thumbsup:
The only damage you can realistically expect to find from hydrolock is bent rods, and the GTi uses the same rods as the 1.6 16v MK4 Golf.
Hows the big block golf engine different to a small block polo engine then? crank throw and piston cc's? Just curious as to what makes it a big block when a important part of it is the same as the small block.
It's not a tall block. It's the same as the AVY but without vvt and cast for the 02 series gearboxes.
The 1.6 8v engines were tall block.
