Polo 6n strips
Hey everyone I've took the bump strips of my polo 6n but laquer has come off on one door what do i do with it ? thanks everyone.
Anyone please ?
Edited by GreatRaz12
Sand it back and respray it, don't look like tcut or anything would pull that back up
You mean respray from actual paint or lacquer ??
Better to paint it all fresh on, if you just laquer it you may see the marks still. Personally I'd sand it right back down to metal and start from scratch
Well i have one door that's gonna be resprayed soon any way so i will experiment with that one i might try some wet and dry 1500 grit and then try t cut ;)
Feather the laquer back to smooth the edges out and local the affected area with a few coats of laquer, then flat that halfway back with smooth wet & dry once hardened, and finally mop it up to a deep smooth shine. You won't see the patch.
No need to disturb the paint itself.
Unless you're going for serious concourse trailer queen levels, and in that case bare shell it by all means.
But with a car that old you won't get as good a colour match as the paint you've already got on your door - so do one or the other, don't just re-paint the door alone or that itself will be one big patch.
Thanks very much have had a go on one door and i have to put lots of pressure on when t cutting but works so well :) Thanks for all your help :)
