Hi Peeps
Hi everyone
Picking up my 2006 1.4 tdi on monday lunchtime, a newbie VAG owner. Just a few questions, what should i be looking for as known problems? Its done 63 thousand on the clock. Also, I've seen numbers flying about everywhere. I presume i have a 9n3 from what I've read on the forum?
Many thanks
Mike
Nothing serious with that engine really. Will be needing a cambelt soonish, which can be a little pricey. The rear consul bushes can wear, normally shown up by a squeak/groan on 'dry' steering (when not moving) and clunk under heavy breaking. Worth checking to see whether they have been done. If they need replacing, be sure to get non-void parts as these should be more sturdy. Check the oil regularly too as mine has a habit of drinking a little. Not sure whether this is a common problem, but it still pulls well and returns good economy
Sorry, just realised this probably shouldn't be in this forum, and i can't find any way to delete it, any chance a mod could move it into the correct forum for me please?
Thaaaaaanks
I think the cam belt got changed at 40k, will double check. And I work at Euro Car Parts so should be able to get the parts cheapish, so will keep my ears open, thanks Prankstar :-)
Thaaaaaanks
Seems like this is in the right section to me matey :-)
