smoothing a mk2 bonnet
I just wondered if i can smooth the grils off the top of a mk2 polo bonnet the ones wher whe washer jets r can i smoothe them off or is the grill importent ??
  • Replies 9
  • Views 1.2k
They're not massviely crucial. They're main reason for being is to vent clean air into the scuttle, to feed the vents, rather than pull it out of the engine bay, and to give a vent if your battery starts gassing.
Ok thanks i should b able to blank them off then
My Mk2 Golf had the vents removed and i didn't notice any difference in heat in the bay.
polos and golfs are both sealed off from the bay..as said its to allow fresh air for the heater fan not for cooling the engine bay
All cars have the heater intake sealed off from the engine bay. There is the potential for an engine to leak fatal carbon monoxide so you can't draw air from the engine bay into the cabin.
A pipe from the heater to a fresh source is fine, such as the front grille or into one of the wings.
So those custom jobs with the bulkhead removed and smoothed are not a clever idea without fresh air to heater?
Edited by dvderlm
Different cars are different. But you'll never see a factory intake pick up in the engine bay - from side partitions like the Metro and 206, seperate exterior compartments like early Fiestas and 70s-80s Hondas, partitions under the windscreen like many '90s> cars, or even ducting from a bay-mounted heater like the BMC cars (original minis for example, when a heater was fitted).
I don't think it's legal actually, to run from the bay, if people get away with it at MoT time after modifying then i think they're lucky it wasn't spotted (or unlucky, in the event of getting headaches or worse..).
that isn't running a heater so no problem there
but no its not a great idea to suck air from the engine bay into the cabin
mine has a pipe feed from the front wing - not engine bay for the very reason of fumes
