Drop plates.
*Please make sure this thread doesn't turn into a 'how to'*
For those who know what they are...
Drop plates- up to 80mm drop, 12mm wide. Bolts included. I bought these as show use only so you are buying at your own risk.
These were them fitted to my 6n.
394347_10150640903422199_1938680630_n.jp
528913_10150637903992199_1943125293_n.jp
282543_10151177338932199_1013858451_n.jp
Contact Chris - 07972 871656
based in NG1 nottingham
£60+pp but please feel free to collect
  • Views 531
Might need to actually explain how they work.. As I don't really see what they do...
They drop the rear 80mm by raising the hub off the stub axle, in affext letting you runat least 80mm lows with the full travel in your coilovers
correct me if I'm wrong :)
looking at the foto above looks like they would onley drop each side about 30-40mm :?
but there defo give your wheals atleast a extra 10m of poke each side :-)
Edited by g40dabbsy
the difference is at least 70mm
imagine a centre line inbetween both groups of the 4 bolts
its more than 30-40, quite clever
The lower bolts mate, do they interfere with the backplate of the brakes? I know i cant run less that 60mm iirc as the bolts interfere with the stubaxle
