Removing 6n2 Roof running strips?
Sorry if I have described them wrong, but how do you remove the two strips either side on the roof (where the roof bars attach)?
Having some stuff resprayed and these are on the list.
Many thanks
Jord
  • Views 2.4k
Roof moulding >09.99
Removing and installing moulding for roof
Removing
‒ Pull roof moulding starting from the rear, off from roof flange.
Installing
‒ Align roof moulding forward edge to roof edge (to guarantee a secure seating the roof moulding must lie flush against the roof edge).
‒ The roof moulding must be pressed from front to rear onto the roof flange
It's held down by some spring steel clips, if you follow the method above, start at the rear and gently pull the trim up, you might need to get a screwdriver to lever it off where the clips are
Removing
Installing
Thank you very much for that mate! Much appreciated!!
