Newbie From Norfolk
Hi all....
have just bought a 2002 9N Polo TDI 1.4
ok its has some issues and I'm sure you guys and girls on here can give good advice.
Love it ,,, have just changed from a Volvo v70 T5 to save on fuel etc...
Ploppy in Norfolk.
Edited by ploppy
  • Replies 12
Welcome aboard fella, I'm sure the guys will be able to help with contacts in Norfolk.
Seen this on sale on eBay, it was up for aaaaages.
Not sure on the alloys but looks like a tidy car :thumbsup:
Hi,
yes indeed was an ebay buy,,,,
great little car ...
Agree on the alloys,,, will probably change them to original spec if I can find any.
Regards
Ploppy
I like the wheels, they are just a size too big for the Polo, shame VW didn't do them smaller.
Welcome along buddy :thumbsup: what are the problems with it?
Hi Matt,
thanks ,,,
well several problems are :
Battery seems to be going flat on start up in morning, just about turns over.
Rear wash wont wont,, push the lever ,, runs out the bottom of the car.
Car headlamps although look very white n bright when driving rubbish..
Ploppy
welcome to CP ;)
If you've got a multimeter test the battery and the output from the alternator, battery may be on its eay out with this recent weather. If not get a garage to do a charging systems check (this will test to see if thee is any amp drain or anything) then go from there.
Not sure where the rear washer is on that shape but if its in the high level brake light pop it out and make sure the pipes connected if it goes to the wiper itself then pop the boot trim off and see if its all connected, just sounds like its popped off somewhere... Is it pissing out from the rear or front?
Get your headlamp aim checked at a MOT station, but first remove the headlight bulbs you say they're white so I imagine they're either HID's (which I doubt as they are bright as fuck) or someones fitted crappy bulbs which you can usually tell as they have a blueish film on part orcall of the bulb
Hope this helps buddy
Matt,
thats great advice thanks...
going to have a look tomorrow.
Will be getting things sorted in 2 months time or so.. lack of funds and moving !!!
Ploppy
Hi mate I'm from norwich too with a 9n!
I have the exact same problem with my rear washer aha!
Hi Louis
Maybe we need to get together and sort out our 9Ns
Also had a problem with the front lights seemed very bright but crap when driving..
Ok there look light ebay specials and the lights had no clips in to hold bulbs in... so will need to get some new lights in the future ,,
Hey ho !!
Plops
I'm from norwich too with a standard looking royal blue mk3 polo gt breadvan with 'burts boyz speed shop' on the rear window. Give me a honk :)
