Rotted boot well
Hi, I have got a p reg polo 1.4 6n, I bought it about a month back and wanted a project but I think I have found a big big problem with my new little baby... My boot well(where the spare goes) has rotted and there is a hole, can I repair it or is it elli mr scrap man, I have been told it will twist my Chassis.
  • Views 963
Twist your chassis??? Nothing will happen to your chassis if its just in the boot well, aslong as its just the body thats rotten and not the main chassis, if its just a hole just cut a plate and weld it up :)
the boot was the least of my worries when it came to rot altho id a mostly stripped shell as a project. cut it out, weld in fresh steel, seal it up, sorted.
Isn't it a big job? Taking out the fuel tank? Might have said my body not chassis lol I can't really remember as long as I can fix it then I'm happy thanks for your help
Make sure you check the rear suspension turrets for any sign of rust as well
Okie and thanks hope I can fix
not a major concern..and that alone wont cause any body or chassis twisting problems , but maybe have a good check for rust elsewhere before spending on it
should be able to get a plate welded on for £50...or more for a smarter hidden repair
Yeh hope so starting to have a love hate relationship with it at the moments gear box oil all over the bottom of my engine, I have a idea how to repair the boot and gonna have a good look for othe rust around the car poke my fingure through the bottom of car (mot failure) but I can fix that easy enough.
