Damp under my carpet
Right I'm convinced there's water dripping in from the under tray in my polo on the drivers side, and I changed my carpet last weekend and under the carpet the deadening was really wet, I was wondering in its the rubber bonnet seal that's letting water in and that's why it's dripping down? Don't think it's the door seals though
  • Replies 10
  • Views 1.8k
Have you got a sunroof? as the drain tube runs behind the A pillar trims, then through the bulkhead into the engine bay.
Yeah I have :/ could they be blocked or something then?
Yes blocked or more likely split/damaged
Oh crap right okay thanks very much. Any idea where I can get any diagrams for stripping and rebuilding?
Sliding/tilting roof with glass panel > 09.99
Cleaning water drain hoses
Front water drain hoses:
The front water drain hoses -1- are routed in the "A pillars" and end between door and A pillar. Cleaning is done from the sliding/tilting roof panel aperture.
1 - Front water drain hoses
2 - Water drain valve
Note:
For cleaning, a locally manufactured tool made from a speedometer inner cable, approx. 2300 mm long, is recommended.
Cheers mate! So they run from the sunroof back to the rear of the car too, I'm hoping its just a blocked drivers side front one, so ill run something down and see what I can do. Cheers
Rear water drain hoses:
The rear water drain hoses -1- are routed in the "C pillars" and end behind the bumper cover. Cleaning is performed from the lower end of the hose. To do this, the bumper must be removed.
1 - Water drain hose
Note:
For cleaning a locally manufactured tool made from a speedometer inner cable, approx. 2300 mm long is recommended.
Edited by nige8021
Are the 6n the same as a 6n2 sunroof wise?
Same diagrams and wording in the manual, so yes
Brilliant mate thanks for the diagrams much appreciated :)
